Chronic front "U" bolt loosening problem
Discussion in 'The Garage' started by opfor2, Sep 29, 2006.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I'm having a chronic problem with the front suspension U bolts loosening up on by 90 Blazer. I would tighten them to spec's and after a few month of driving they would loosen up again. This would be evident when I hit the brakes I would hear the front axle "clunk" both right and left. So what would be causing the u bolts to loosen up? This is getting old and frustrating.. Any ideas ???
  2. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    thay are streched out and shot. junk them and go buy some new ones. 5/8 rod is best. its stronger than the avarage size some places like to give you.
    i dont tourqe mine. i just run them on with the impact. havent had one come loose yet. but never reuse ubolts. this is the kind of problems you will find with them.
  3. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    My guess its a combo of stretched bolts and worn nuts.... Like sweetk30 said, replace them, places that make them include all new hardware and it will hold great.
  4. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    get new ones. run them on with a gun then yank em down tight with a breaker bar. I have never had a problem with new ones. tighten once about a week later then thats it.
  5. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    OK, any suggestions on were to get new ones??
  6. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    spring shops should be able to make anything you want. I know offroad design can get them for you.
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I would start by looking in the phone book for a spring shop. Maybe look under trailer supply section or something. That is how I found one here in Vegas. Take your old ones in, keep in mind the front axle uses 1 different size u bolt around the housing. Most shops bend them right there and provide hardware to boot:)
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    and if they give you a regular nut, throw it away, and get some prevailing torque lock nuts. we use them all the time on 50,000# motorhomes, i dont see any reason not to use them on a truck that weighs 1/8 of that.
