Chrysler 9 1/4 axle
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChadH82, Nov 27, 2001.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    Has anyone ever used this axle? My friend was thinking about getting one for the rear of his land cruiser. I was wodering if anyone knew of any problems with them besides being under dodges? The 9 1/4 ring gear sounded good to me but does anyone know the diameter of the axle shafts? Any other specs or thoughts?
    Chad
  2. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    There anit much aftermarket for them, i.e. :Locker/gears...........ect.
    I have not worked on one for many years, so if its the one with the spanner nut adjustment for the axle, stay away
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    To get 4.56 gears in, you have to grind one of the ring gear teeth to get the crosspin in.
    You are better off to go with the GM 9.5" SF 14 Bolt. You get the ring gear diameter you want, along with 33 spline axle shafts, bolt-up brakes and spring pads, and you can get one to match either the 6 lug or 8 lug bolt pattern that is on your rig
    They are cheap, and you can get lockers and 4.88 gears.
