Clank when starting
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77GMC15, Nov 23, 2002.
  1. 77GMC15
    77GMC15 1/2 ton status
    Mar 14, 2001
    110
    Vacaville, CA
    Just put everything on and when I go to start it there's an ear-shattering clank from near the starter. I checked out the flywheel and it isn't missing any teeth or have any that are trashed, but some of them are silver like they were grinded from the starter or something. Do I have the wrong starter or will this go away if I go all the way to starting it and letting it run?
  2. vince13
    vince13 1/2 ton status
    Dec 6, 2001
    105
    Penticton, BC Canada
    You need to shim your starter. if you bought a new starter it should come with a shim.
  3. 77GMC15
    Mar 14, 2001
    110
    Vacaville, CA
    Oh why thank you mr vince13
  4. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    it shouldnt make a grinding when it engages if it is to close. you should have a 1/8" soace between the starter and flywheel.once u get shims, u'll understand. then just engage your solenoid after u get the shims on and see how it looks. but dont leave it engaged for more than 30 seconds, or it will burn up the solenoid. o yea, its normal if the solenoid doesnt disengage until the truck is started. good luck
    NITRO
