"Clanking" noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1TUFF89, Feb 8, 2002.
  1. 1TUFF89
    1TUFF89 1/2 ton status
    Apr 6, 2000
    109
    West Point, Virginia
    \"Clanking\" noise
    I get a loud "clanking" noise when I put on the brakes and stop. I don't think it's my brakes, though. My brakes do squeak, though, but that's not unusual. What could it be? My u-joints are only a year old and they are heavy duty. Could it be my rear end?
    CHEVY - "THE HEARTBEAT IS GETTING LOUDER"
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: \"Clanking\" noise
    di yiu have a lift? i know the front springs sometimes bottom out on the frame and clunk loud when the brakes are applied hard or with off roading....
  3. 1TUFF89
    Apr 6, 2000
    109
    No lift (yet). I've heard it all this week and am not sure what it is. Doesn't sound too good, though. Anyone have any ideas?
  4. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    Finding the clank is easy, just make the noise happen repeatedly and as hard as you can until something breaks. When something quits working you will know what it was. haha Just kidding. Does it happen when you just start to brake or when the braking force starts to pull the nose of the truck down? If it happens when you first hit the brakes it may be a loose caliper. Just a thought.
    Jamie
    Pics at <a target="_blank" href=http://community.webshots.com/user/jlblmkh>http://community.webshots.com/user/jlblmkh</a>
    (Formerly heaj1)
    Swimmin like a rock, slingin like a stock, but not for long.
  5. 1TUFF89
    Apr 6, 2000
    109
    it happens when the braking force makes the nose of the truck go downward.
  6. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I had this same symptom on mine for a while but I can't remember exactly what it was. I would check the following...
    1. U-Joint retaining bolts for tightness
    2. Shock mount bushings
    3. Spring Mount U-Bolt Tightness
    4. Transmission to Motor bolts
    5. Front body mounts (especially under the doors)
    I imagine you hit up most of these, hope I hit something you missed.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
