Clean Engine compartment?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by UseYourBlinker, Sep 12, 2000.
  1. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Hello all,I wanted to clean up the engine block today.My question is what do you guy's and girl's use to do this with? and what to I have to cover or protect? 84K5,stock 350 with AC.
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,069
    479
    Grand Rapids area
    I like to keep my whole engine compartment clean and shiny and here's what I use:
    Engine degreaser - any brand will do. Autozone and Wal-mart both have their own for $1.00 or less. One can is probably enough.
    CD7 (or something like that) Engine Detailer. This is available at WalMart, among other places that creates a protective coating over everything in the engine compartment.
    This technique makes the engine compartment look like a new truck and it lasts a long time and makes keeping it clean easier.
    Find a place where you can make a big mess on the ground.
    Take off your air cleaner and cover up the input to the carb so that no junk can get sprayed in it.
    Spray the degreaser all over in the engine compartment, even on the firewall and wheel wells.
    Let it sit according to product instructions
    Get a hose with low pressure and hose all of that crud out of the engine. Avoid getting water in the distributor, carb or breather (or anything else that logically shouldn't have water in it. It is fine to get the block/heads wet. Stuff that looks like dirty milk will run everywhere.
    Allow to dry (read the can)
    With the carb still covered, spray the engine detailer all over your engine, fan shroud, hoses, firewall, wheelwells, etc. Don't spray it on your belts, in the alternator or in the carb.
    Once it's done dripping, just run the truck to get the stuff hot so that it cures.
    Now everything is very clean looking and shiny (not high gloss, but a neat, even satin). It will also be easier to keep the engine clean now.
    The detailer is not harmful and can be cleaned off with more degreaser or some elbow grease. It is MUCH better than trying to use Armor all under the hood, since Armor All will be washed off in the first rain.
    '85 JIMMY
    '90 paint/grill/trim 5"susp 33/12.5/16.5
    Fresh 350 B&M '87 TH700
  3. sosamantx
    sosamantx 1/2 ton status
    Aug 14, 2000
    393
    somewhere in Texas
    <font color=blue>Heck, all I have ever done is take the air filter off and just throw a rag over the carb (they do advise that you cover the distributor cap as well, I haven't had to do this though) and just have at it. You can just buy an engine degreaser (they are all about the same), spray it on and wait a little and rinse it off. But whatever you do, don't go there with a hot engine, just warm, like you haven't driven it yet and you drive straight to the carwash and do this. You don't want to mess anything up. - Steve</font color=blue>
    <font color=red>You can check out my engine bay on the link below, however this is in my Nova, my K5 isn't running yet and it looks like crap right now (I am a new owner).</font color=red>
    <font color=blue>Steve Sosa a.k.a. "sosaman"</font color=blue>
    http://sosaman.home.texas.net/carpics.html
  4. UseYourBlinker
    Jun 7, 2000
    11,117
    Thanks,to the replies I am going to clean it later today...
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
