cleaning a radiator while out of truck ?
Discussion in 'The Garage' started by sweetk30, Nov 14, 2006.
  1. sweetk30
    Nov 1, 2004
    25,544
    540
    horseheads , ny 14845
    i have a nice rad from a parts truck. the motor was bad and thay had sealer in it along with other stuff. the rad has a white chunky film in it but looks like close to new or super clean. its a brass/coper style unit. what can i use fill it and let sit then fluch it out with a hose to remove this junk. thanks for any input.
  2. dremu
    Feb 27, 2000
    15,961
    452
    East of San Francisco
    Seem to recall that Prestone makes a goop called Radiator Flush... hmm... yep:
    http://www.partsamerica.com/ProductDetail.aspx?categorycode=3285&mfrcode=PST&mfrpartnumber=AS107
    -- A
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    muriatic acid... available at the hardware store.. mix it 50/50 with water.. Let it sit in there about 15 minutes...
  4. sweetk30
    Nov 1, 2004
    25,544
    540
  5. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    If its out already, take it to a radiator shop and have them boil it out. A good shop will also pressure test it, so no surprises when you install it.
  6. dyeager535
    26,980
    An dif they are really good, they'll flow test it, which is the only way to make sure a radiator will actually cool as its supposed to.
    You will never get all the crud out of a radiator with flush, acid, vinegar, whatever you want to try. BTDT, having pros boil it may work, as long as its in good shape and as mentioned doesn't leak under pressure.
    You can't see the condition at the bottom of a radiator, and even if it looks good up top, down low may be packed full of corrosion.
