Cleaning Axle Tubes
Discussion in 'The Garage' started by B_to_C, Jul 27, 2005.
  1. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    How do you clean the inside of axle tubes? A big ol' pipe cleaner or what? There's a bunch of rust and crap in my Dana 60 front that I want to get out. Thanks. :1zhelp:
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    First use a vacuum cleaner with a couple extensions on it to get all the loose stuff out. Then make a home made pipe cleaner using a broom stick handle and a rag to wipe down the inside of the tube. You can also cut a 2" pvc pipe (I think that's the right size) in 1/3's length wise and lay it inside the tube and leave it there. That way when you're out on the trail you can just pull the pvc pipe out and clean it off so when you slide the axle shaft back in it'll be clean.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    I wonder if you could use a chimney sweep for this???
    mabye cut the steel bristles down to size with sme wire cutters, thast would get everything out
  4. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I used a shotgun cleaning kit. It seemed to work pretty good.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I made my own tube cleaner out of a flexible wire wheel about 1/2" bigger in diameter than the axle tube, threaded it into a piece of 1/2" steel rod about 4 feet long, mounted it in a drill motor and went to town cleaning after spraying the crap out of the inside with brake kleen. Worked slick :thumb:
  6. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    make one..
    We used a large washer welded to a metal rod to scrape crud and roller bearing "logs" out of axle tubes at work..sometimes if we pulled the diff out,we'd use a pressure washer or steam cleaner to give it a good bath...and blow it out with the air hose good...the wire brush/electric drill with an extension rod sounds like a good idea too..
  7. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    I use a ski pole with a round basket. The plastic basket is oversized enough so it's a real tight fit in the axle tube and scrapes all the junk and scale off the walls.
  8. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Does it hurt anything to just not clean them?
  9. B_to_C
    Jan 15, 2003
    1,861
    Thanks for all the tips guys :bow:
    That's a good question
  10. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Dang, lots of complicated solutions for a simple problem. A simple $2 round toilet brush duct taped to the end of an old broom handle does an excellent job of cleaning out axle tubes. :rolleyes: Use a bit of aerosol engine cleaner as a solvent and swab 'er down.
    DON'T use a chimney sweep! The metal will scratch the crap out of everything. :eek1:
  11. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Only problem I see with not cleaning them is when you install an axle, you will most likely scrape up some crud and end up with that in your diff. Of course you could not clean them and do the PVC trick mentioned earlier and be ok.
