Cleaning axles for paint...need some tips!
Discussion in 'The Garage' started by stallion85, Apr 16, 2004.
  1. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    Ok I am prepping a 14 bolt and d44 for paint. So far I have used 3/4 of a bottle of b-52 and wire brushed the 14 bolt. It took almost an hour to just do the carrier /forums/images/graemlins/blush.gif Just wondering how everyone else did this. It's gonna take me longer to clean and paint these than it is to swap out the axles /forums/images/graemlins/angryfire.gif
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    easy off oven cleaner and a pressure washer /forums/images/graemlins/waytogo.gif
  3. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    sand blast it! /forums/images/graemlins/peace.gif
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Angle grinder with twisted-wire cup brush...Took ALL the crap off my D60 pretty quick
    Chris
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The last set of axles that I bought went to the high pressure car wash while they were still on the trailer that I was bringing them home with. /forums/images/graemlins/eek.gif I sprayed 'em down with Gunk engine cleaner and then blasted off the years of grease and grime. Took maybe 15 minutes and cost about $4. /forums/images/graemlins/thumb.gif
  6. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    greased lightening then wash with heated pressure washer then go back with purple power stuff (sold at advance auto) and spray and let sit for bout 5 min and pressure wash it again- KMART has the best flat black spray paint ive ever used...88 cents a can...u can afford to put a couple of good coats on it....trust me, it looks sweet with clean painted axles!!!!! hope i helped
  7. stallion85
    Jul 11, 2003
    3,659
    Cedar City, UT
    That sounds like some good tips, I got a wire cup brush for my angle grinder and am going to go to town on them this morning. As for paint I already bought Krylon Rustoleum. I got it on sale in "Pink"! Do you think the axles will look sweet or what?/forums/images/graemlins/histerical.gif Just kidding, I got black /forums/images/graemlins/thumb.gif How clean do these have to be to paint. Can I just get all the grime off then paint or should I get the rust off too. I don't think I have enough time for the latter. Thanks for all the tips so far. I might try that easy off oven cleaner trick /forums/images/graemlins/waytogo.gif
  8. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    2nd vote for this. This stuff will strip them to bare metal without you having to break a sweat.
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I tried just using a wire wheel in a drill to clean my SM465's and a few t-cases. It took FOREVER! It was all I had though... /forums/images/graemlins/grind.gif
  10. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Mine were real bad. I bought 4 cans of engine degreaser
    and every night after work sprayed the down for about a week took them to the car wash look like new after that.
  11. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Chris
    Same as me, wore that brush out too. I had little wire quills stuck in my skin /forums/images/graemlins/rotfl.gif Then a bottle of engine degreaser and a trip to the car wash /forums/images/graemlins/grind.gif
  12. tucsonkfive
    tucsonkfive 1/2 ton status
    Jun 9, 2002
    133
    Tucson, AZ
    Another vote for oven cleaner. Rustoleum has a primer that's for rusty surfaces. A couple of coats of primer then hit it with the black stuff. /forums/images/graemlins/thumb.gif
  13. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Good tips guys! I may have to do that someday soon...
  14. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Chris
    Used this meathod before when a sand blaster was not available. It would be my second choice if you dont have access to sandblasting.
  15. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Yeah a drill won't cut it..4"+ angle grinder worked great for me..>I've tried a wire cup brush in the drill...doesn't do jack squat...
    Chris
  16. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    I've found that a wire wheel doesnt work so great...it takes the grime and rust off but also 'polishes' the surface and they paint chips off VERY easily. If you do wire wheel it, I would suggest scuffing it up with some sand paper before the paint is applied. It will stick alot better and be a little more durable.
    I've always just pressure washed them with some hot ass water. helps having friends that work at places that they have the big ass boiler hooked to a pressure washer /forums/images/graemlins/peace.gif
  17. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    Another vote for sandblasting-no better way to clean and prep for this type of job imo. Also gives a great surface for POR15 if you decide to use it-soaks it up into the pores of the metal-just be sure and topcoat if it gets an UV. I've been topcoating the POR15 with Rustoleum gloss black while it is still tacky-no long term results but should provide a little more resistance than just the spray bomb.
  18. 90blzr
    Mar 25, 2001
    3,027
    SO CAL
    I agree, but you better make sure every seal and opening is covered up. Sand gets in EVERYTHING! Sand, grease and bearings dont mix /forums/images/graemlins/grin.gif
    The do come out sweet though when done right! Just make sure you take the extra time to make sure sand cant get in anything and you are good to go /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
  19. JSH
    Oct 20, 2002
    75
    Iowa
    Good point-just to be safe I changed gear oil after doing mine and was careful not to blast directly at the hubs-sand in the bearings/seals would not be good.
  20. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    I agree with that...I ran my DA sander over the whole thing after wire-wheeling it and before painting it...
    Chris
