Cleaning driveway of heavy grease/oil slicks... need how to?
Discussion in 'The Lounge' started by jjlaughner, Aug 20, 2003.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I used what little absorbant stuff I had when working last week. Now I have some oil spots I need to get rid of. I used a whole tub of the Oxy-Clean stuff in paste form and rubbed it around with a brush and rinsed it off, it helped a little bit but not to the liking of the folks /forums/images/graemlins/tongue.gif
    Need something cheap that works thats not extremly hazardous (we have well water) /forums/images/graemlins/confused.gif /forums/images/graemlins/ears.gif
    I pickup some thompsons water sealant will that help keep new stains from setting in after I get the old stuff cleaned up? /forums/images/graemlins/thinking.gif
  2. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    It's called purple power or something like that. I'm too lazy to walk out to my garage and find it. But it works well with a stiff nylon brush or a power washer...
  3. powerbitch
    powerbitch Registered Member
    Jul 21, 2003
    76
    Deer Island, Oregon
    all the mecanics i know including my ol man use cat litter it seems to absorb it up
  4. got_mud
    got_mud 1/2 ton status
    May 9, 2003
    316
    Wichita, KS
    powdered tide with bleach. grind it in real good and let it set for a day in the sun. scrub off with water or high pressure wash it and you should be good to go.
  5. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I think this is the Castrol Purple Cleaner. Really good stuff for cleaning grease/oil. I have had very good success with it. You can also try Muratic Acid (Swimming pool acid) but be careful with that.
    You can also try and pre-soak the area with some Dawn dishwashing soap. It works well on grease too.
  6. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    At the gararge I used to work at to clean the floors they used this orange powder that turns green when wet. This stuff works really good. I think its a zep product. Its looks just like tang. People use to call the police on use thinking we were rinsing the parking lot with coolant, well it looks just like it when wet /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  7. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    -Coca-Cola. Attracts lots of ants and bugs, but cleans the spots nicely too.
    -Greased Lightning. Pour it on straight out of the bottle, brush it a bit, let it sit for a while, rinse.
    -Tide powder. We've used it in the past to clean our helicopters after desert ops and massive oil leaks, works great.
  8. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    Oh, btw, sorry for the mess. /forums/images/graemlins/blush.gif
    I've had some good luck using oven cleaner, "Easy Off" brand. Spray it on, let it soak for a few minutes, srub a little, then rinse. The tricky part would be getting up all the cleaner without any washing into the yard. If you leave the stuff on too long it could erode the surface of the concrete, but the stuff is designed to remove grease and oil.
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    hmmmm... I'm thinking of using oven off on my silver trucks axles (to remove the layers of paint). I wonder it would hurt the seals or anything? I'll make another post sometime.
  10. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i use tide powdered laundry soap and an asphalt broom. get it wet, pour tons of soap on it and scrub it with the broomn and rinse it off.
  11. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Can you rent a pressure washer? That would probably work pretty well... </font>
