Cleaning Engine?
Discussion in 'The Garage' started by socal chevy, Aug 23, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    I am in the process of installing a 350 in my k10 and I wanted to clean the engine up a bit. What should I use to get rid of all the grease and grime? Thanks
  2. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    Kids, Wife. Anything with small hands & lots of rags.
  3. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I mean what kind of chemicals, etc... to clean it up GOOD.
  4. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Eazy off oven cleaner, the spray on type.
  5. K30Blazer
    K30Blazer 1/2 ton status Premium Member
    Mar 26, 2003
    810
    204
    Santa Barbara, CA
    I have heard that Oven Cleaner can actually damage seals etc. Gunk is the best stuff I have heard of, but then again small hands are always going to be the best. HAHAHAHA
  6. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I like GUNK it smells like diesel to me and it cleans really well. Not that I smell it a lot but oven cleaner def dont smell good. :laugh:
    Ira
  7. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    I second the EZ off oven cleaner. The best thing is to spray it on and let it sit for about 10 minutes then use hot water if you can with a high pressure nozzle on the hose and soon you will have a super clean engine. I also have never heard of it damaging seals and i've used it for years now with no issues with bad seals.
  8. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    carb cleaner works awesome
  9. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Don't use the oven cleaner if you have an aluminum intake, or any other aluminum parts, it wil oxidize the AL like a mofo.
  10. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    Yeah I have alluminum Edelbrock valve covers...Thanks for the warning! =)
  11. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    steam cleaner :D
  12. sunnyc123abc
    sunnyc123abc 1/2 ton status
    Mar 12, 2005
    636
    SoCal
    Engine Degreaser?
  13. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I always here about that... What exaclty is it, and how does it work?... I know steam cleaning for carpets...but for engines...im confused.. :confused: :D
  14. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    In the simplest of terms a steam cleaner is a pressure washer that used hot water in this case steam. Works wonders well worth paying someone to do it. Carefull with the gunk and other stuff a buddy of mine did it at night at a diy carwash and the guy that owned it just happened to pull in at the same time to wash his truck. Long story short it is a against the law and my buddy got sued and had to pay the guy 1500 bucks for some EPA fine just be carefull
  15. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    theonly degreasing chemical i use is kerosene
    usually engines and trannies i take to local car wash and use the engine degreaser, i plug all engine holes with plastic grocery store bags
    works great, only spend a coupel bucks to wash en engine or tranny, then after a quick dry time its ready too paint and install into vehicle
    i dont evne prep clean.scrape before car washing them, but you could i guess.
    i use kerosene for small stuff like starter motors, and when are scraping off axle housings, etc
    good luck
  16. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    Simple green and water.
  17. tavis
    tavis Registered Member
    Mar 13, 2004
    11
    Gunk is the good stuff. Works like a charm.
  18. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    get a thing called super purple. you can get it a t wally world or a cheaper version called purple power at parts stores. before you spray it on, you might want to dilute it a little because i used it on my motor just as it was, and it ate the grease off in minutes, but it was starting to eat my paint off too.
  19. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I should also mention that I dont have access to a hose where I am trying to clean it. Its in my garage, and my association is majorly Anal! The only hose I got is in my patio, and I cant do it there! :D So I need a cleaner that I can soak on, and wipe clean.
  20. Roz
    Roz 1/2 ton status
    Mar 27, 2005
    900
    San Diego
    simple green automotive concentrate is the shiz. i use it for mine and in my parts washer. i put pitons in it, next day pulled em out and BLING. its cleans awsome. and u can dump it in the sewer. u can use it at the diy car wash too. have let it soak a little bit though
