Cleaning mud from brakes.
Discussion in 'The Garage' started by FL84K5, Jan 27, 2003.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    What's the best way to clean out the brakes after going mudding? What should I do to get all the sand out of the rear drums? Pull the drums and use compressed air to get all the sand out and then use brake cleaner? Would the same method work well for discs, if it works at all? Now I know why rear discs are so popular. /forums/images/graemlins/crazy.gif
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I used a hose,
    fullfloaters are a XXX to clean drum brakes as you would have to expose the bearings to the contaminants.
    I was contemplating cutting access holes in the backing plates but as you stated rear discs is the answer
    and they are cheaper then replacing the drums after they are siezed
  3. MUD JUNKIE
    MUD JUNKIE 1/2 ton status
    Oct 24, 2001
    379
    Reddick,florida
    hose them out real good,and watch out using compressed air when cleaning drums out dont breathe the dust /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  4. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    I usally just pressure wash the mud out at the local wash house. just stay on the brakes till no more muddy water comes out for each wheel then agin when i get home with reg. hose low pressure so you can really tell what color the water is. /forums/images/graemlins/deal.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif www.zombieoffroading.8m.net
