Cleaning My 1 Ton Axle
Discussion in 'The Garage' started by 4wheelin4Jesus, Sep 30, 2005.
  1. 4wheelin4Jesus
    4wheelin4Jesus 1/2 ton status
    Mar 20, 2005
    149
    north carolina
    Im rebuilding my 14 bolt rearend. Its got a lot of old grease, and oil in it. My buddy said to fill the hogs head with Kerosene. He said that it would clean the grease out without adding any water to rust the interior. Is this true? If not, what should i use.
    thanks
  2. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    I would use break parts cleaner works good dries fast
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    yep me to. plus you get real high :p: :screwy: :whistle:
  4. 4wheelin4Jesus
    Mar 20, 2005
    149
    north carolina
    any other sudgestions?
  5. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    I used one of those cheap cotton dusting wands to clean out the axle tubes with solvent. Dip it in solvent, shove it down the axle tubes a bunch of times, rinse and repeat. After they are fairly clean, finish up with brake cleaner.
  6. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    Kerosene or Diesel works great.
    when i repack the hubs, i didnt feel like being there for 3 hours with 10 cans of cleaner.
    i tossed them in a bucket and filled it with Diesel.
    2 days later, all the grease was at the bottom of the bucket.
  7. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    You need one of those twin 55 gallon parts washers that I've seen on here at some point. Awesome! One picture even had a 14 bolt in it if I remember correctly. Sweet!
  8. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    soak it in diesel, scrape off what you can, whats is left use oven cleaner, let it sit for about 30 min, hose it off.
  9. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i used some engine degreaser and a pressure washer on mine with no ill affects or rust. just blew it out and set it in the sun to dry.
  10. SCOOBYDANNN
    Sep 4, 2001
    2,131
    25
    El Paso, TEXAS
    I had a major realization the other day when i was using engine degreaser to clean off my frame.
    It all started when i was working on a ranch and all we used to "degrease" was Diesel.
    Flash foreward to the day in ?, i sprayed a new can onto the frame. when it is in liquid form, not too foamy it is pinkish red in color. it dawned on me---------engine degreaser IS diesel, probably just watered down. go get a thik type spray bottle and fill it with the pink stuff for a lot cheaper.
  11. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,493
    1,193
    So Cal.
    you mean this one :D its my parts washer i built, and yes i have showed it off several times before. i finally ordered 20 gallons of solvent, 250.00 worth! my tank holds more then that. i am very proud of this i must say, its about the only project i have actually finished.
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Me likes! Me likes! :bow: :bow:
