cleaning old engine parts???
Discussion in 'The Garage' started by potionmaker, Jan 23, 2006.
  1. potionmaker
    potionmaker 1/2 ton status
    Jan 6, 2006
    177
    USA
    Hey All...I'm in the middle of an engine change and need some advice for a good solvent to clean grease and grime off of all of the brackets and such that will be reinstalled. Any advice on what works best would be much appreciated?
    Thanks,
    BB
  2. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    if i remember corectly i use this stuff called castrol super clean, or something along those lines, comes in a purple gallon jug. it has always worked great for me.
  3. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    I like GUNK. comes in a spray can(white with an orange top). Just cover the stuff with it--let it sit and rinse off. It has worked really well for me.
  4. potionmaker
    Jan 6, 2006
    177
    USA
    Thanks for the input!!. Anyone else have any tricks???
  5. 1-tonmudder
    1-tonmudder 1/2 ton status
    Apr 24, 2005
    3,052
    In a junkyard somewhere
    Both of the above mentioned work well,but the super clean is kinda pricey.I go to the dollar store and get oven cleaner.It is very strong smelling so you will probably need a paper mask.Spray it on,let it soak and spray off.For the really hard stuff like cases and diffs,you might have to scrape it after the initial cleaning and then spray it again.Usually by the second time it's pretty clean.
  6. txpitbull2003
    txpitbull2003 Newbie
    Nov 26, 2005
    4
    Tyler,TX
    Same here, used oven cleaner from dollar store. Cheaper, and worked alot better.
  7. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    oven cleaner for the nasty stuff
  8. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,034
    1,349
    Kzoo, Mi
    keep that stuff away from aluminum though, Its caustic which will eat aluminum, yeh I've been there.
  9. rdn2blazer
    rdn2blazer 1 ton status Premium Member
    Jun 9, 2004
    16,487
    1,192
    So Cal.
    will eat paint too.
  10. 88trailblazer
    88trailblazer 1/2 ton status
    Apr 11, 2004
    425
    Miami, Florida
    At an old job we had a parts cleaner that ran mineral spirits. This works great and the fumes aren't to bad
  11. 1-tonmudder
    Apr 24, 2005
    3,052
    Yeah it's in my parts cleaner too
  12. 77crewcab
    77crewcab 1/2 ton status
    Feb 9, 2004
    1,620
    Lubbock, Texas
    At my job we have parts washers, but if we really want something clean we use the hot tank or the hot water pressure washer. Works great! At home I use the super clean, simple green, and if that doesn't do it then I take it to work.
  13. JSH
    JSH Registered Member
    Oct 20, 2002
    75
    Iowa
    I second the Simple Green-full strength. Seemed to work as good for me as traditional engine cleaner and is also biodegradeable and smells alot better. I use it for just about all of my cleaning anymore.
  14. ike
    ike Registered Member
    Jul 5, 2005
    96
    orange ca
    A dish washer works great... You can get one used for cheap..or if you live at home just use your moms
  15. clstolten
    clstolten 1/2 ton status
    Sep 4, 2002
    356
    I like the dishwasher idea, if you could find good way to keep the grit from getting in the pump. A college roomate and I pulled some good sized rocks out of the skunk river so that we could put them in our fish tank. We ran them through the dishwasher in our apartment. Rocks were damn clean, but the dishwasher made some goofy noises after that. Maybe use some fine mesh at the water intake, and use simple green as degertent. Just don't let your mom find out.
  16. ike
    Jul 5, 2005
    96
    orange ca
    Dishwasher Parts cleaner
    Yea a guy at my work has one set up in his side yard... I really don't think its cool how he has the drain going in his main ...out to the ocean .. but the dishwasher works good .... does a great job on cleaning.... I would set the drain up into a tank and drop off the waist at the recycle dump..Or even toss the jugs in the trash can... I would rather it go in the ground at the dump then in the ocean....
