cleaning out fuel tank with diesel??
Discussion in 'The Garage' started by BL1TZKRIEG, Oct 13, 2005.
  1. BL1TZKRIEG
    BL1TZKRIEG 1/2 ton status
    Jan 4, 2005
    196
    OREGON
    would it be ok to clean out my gas tank with diesel?
    I just replaced my fuelpump and sending unit and want to flush my tank out.
    I have a TBI would it hurt anything if a little diesel was left in there?
  2. dyeager535
    26,982
    191
    Personally I'd leave a bit of gas in there, swish it around and use a rag to pick up any of the junk that settles. That's what I did. If you are worried about junk in there, whatevers left should be strained by the pump "sock" filter, and after that, the fuel filter.
    Diesel isn't a better solvent than gas is it? (general question)
  3. monster man
    monster man 1/2 ton status
    Oct 20, 2003
    282
    Reno, NV
    no, but it's less volatile. It's good for cleaning dirty car parts and chains and whatnot. The diesel in the tank will be fine as long as you get most of it out, the rest will dillute when you add gas. Running diesel througha gas engine is much better than gas througha diesel engine..... KABOOM
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I use kerosene, it works great as a solvent.
  5. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Diesel ok,but..
    Laquer Thinner or Acetone will be a much better solvent than gas,diesel or kerosene..also a lot more flammable,explosive,and expensive!..but thats what I use on old lawnmower carbs that are full of hardened shellac,I soak them a few days in Acetone or MEK (a similar solvent)..works when everything else fails..if you cant get it clean with that stuff,nothing else is going to work!.. :crazy:
    Diesel or Kerosene makes a great de-greaser for engine blocks,rear ends,manual trannies,etc..much safer than gas or thinner..not so great on varnish or shellac in fuel system parts though..gas is a better solvent,but a lot more dangerous..I dont use gas or thinner indoors,not since I added wood stoves in my garage! :eek1: :crazy:
  6. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    If your tank is galvanized inside be careful the diesel eats up the zinc if it is in there long enough and will gunk things up.
