cleaning R and P
Discussion in 'The Garage' started by 69K5, Nov 9, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I want to clean the gears in my axles D44 front and eaton rear. 15 years of sludgy oil water and trash. Whats the best way to do this w/o removing them since ive never done that before. seemed kinda expensive to waste that much wd40. figured that spraying with brake cleaner and lighting it would kil the bearings and seals /forums/images/graemlins/rotfl.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    thanks in advance
    69k5
  2. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    Why would you "Light It"? Just use brake cleaner and be done with it! Let it sit for 10 minutes and it should all evaporate! Can't get much cleaver than that! /forums/images/graemlins/deal.gif /forums/images/graemlins/thumb.gif
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    saw on one of thes post where someone was doing that. i dont remember what it was for but they took the gears out sprayed break cleaner on em and lit it.
    monster chev
    what kind of solvent? anything inparticular thats better?
    thanks to both
    69k5
  5. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Actually, i have no idea what kind of solvent we use at work, i will check tomorrow. /forums/images/graemlins/smile.gif
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    all right thanks
  7. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Just use brake cleaner. It shouldn't take more than 1 can.
    Never use solvent on any bearing! It removes the oil by "liking the metal better than the oil". It will sink into the pours and keep oil from sticking to them in the future.
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i was honestly worried about the brake cleaner doing that b/c when it dries it dries everything else hands and all up. i didnt know if that was gonna be good for em or not.
    thanks
    69k5
  9. Klef72K5
    Klef72K5 1/2 ton status
    Apr 8, 2001
    249
    Columbia City, Indiana
    6 yrs ago Dana used kerosen to wash all rings and pinions. Now they have a special detergent that they use. When I blew up my front axle I washed it out with lacquer thinner. I didn't light it, it will dissipate.
  10. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks for the idea. i am probably go with brake cleaner as its cheap.
  11. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    If you use the brake cleaner, and don't plan on reassembling it right away, make sure and spray it lightly with wd-40. The brake cleaner will remove all of the oil and surface rust will appear almost as soon as the cleaner evaporates.
    Just my .02
    Byron
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    will do /forums/images/graemlins/thumb.gif
  13. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yes but with the sovlent, you have to remember, then i wash it in the parts washer and blow it dry. I dont leave solvent on the bearings, or anything fo rthat matter. /forums/images/graemlins/thumb.gif
