cleaning R&P/Carrier ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by KING K5, Apr 3, 2001.
  1. KING K5
    KING K5 1/2 ton status
    Sep 28, 2000
    172
    Sacramento, Ca.
    cleaning R&P/Carrier ?\'s
    I just drained the fluid out of some axles sitting in my garage waiting to go into my blazer and I would like to clean the R&P and inside of the carrier better to make sure I got all dirt particles etc out (I mean I want it CLEAN). Is there anything in particular I should use or stay away from using? Thanks in advance!
    Jeff
  2. BOWTIE
    BOWTIE 1/2 ton status
    Dec 28, 2000
    2,018
    Outside with the sawzall.
    Re: cleaning R&P/Carrier ?\'s
    I've always used some brake cleaner to clean out the inside of my diff. It works really well.
    Hope this helps.
    Ric
    MY K-5 DOESN'T LEAK... IT JUST MARKS ITS TERRITORY.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Go with Bowtie' suggestion- BrakeKleen is the only stuff I use. It really penetrates and breaks up all the crud that has built up farther back in the diff. I'll go through a whole bottle per diff............
    One hint: Make sure you get a rag inside the bottom of the housing and sweep all the leftover cleaner out, or it will dilute your new gear oil and cause it to break down a lot faster. Once everything's cleaned out, I also let the diff sit for about half an hour before replacing the cover to ensure that any residual BrakeKleen has had a chance to evaporate...........
    <font color=red>PHOTO ALBUM-</font color=red> <A target="_blank" HREF=http://albums.photopoint.com/j/AlbumList?u=1289798>http://albums.photopoint.com/j/AlbumList?u=1289798</A>.......<font color=blue>TRUCK & HIKING PICS</font color=blue>
  4. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    I second Canmore's post.
    Will work for beer, parts and tools.
    90 Jimmy 350TBI-700R4-241-33" BFGs-10 bolts w/4.10's
    <A target="_blank" HREF=http://www.nashvillek5.freeservers.com>http://www.nashvillek5.freeservers.com</A>
  5. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I always use an old squirt bottle filled with varsol. It does a good job of cleaning everything out as well. Then use the brake cleaner to dry it out.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Lets Go Wheelin! </font color=red>
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    Yep, I use only brake cleaner on all axle work. This is very simple to use and VERY effective in getting the grudg out FAST!!! Best thing about b.c. is that is dries FAST allowing you to get to work right away. The b.c. also does NOT do any damage to seals, rubber, etc.
    Unless you are doing a total rebuild, and have the axle out of the truck, take it to the pressure wash and use HOT SOAPY water to clean it. Never use plain cold water. Surface rust will settle on the machined areas. Hot soapy wash will clean and get the axle warm enough that when you get done, the water will dry right away and wont leave any surface rust on the machined areas.
  7. timebomb1602
    timebomb1602 1/2 ton status
    Mar 30, 2001
    138
    hudsonville, MI
    also to prevent rust mist with oil [ie wd-40] after cleaning at powerwash. then use brakleen before install
    1991 GMC Jimmy, 350 tbi, stock for now, but not for long!!!
  8. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    let me bring this back from the dead-
    i've been cleaning all my bolts with gasoline and alcohol for years due to the chemical properties of the two. would it be ok to do the same with the spider gears? i want them suckers clean! and the bearings too?
  9. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    /forums/images/graemlins/1zhelp.gif
  10. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
  11. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i would stay with brake cleaner not gas.
    compressed air would be good idea after spraying with brake clean
    good luck
  12. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    too late- oh well, gas can't hurt too bad. i'll do brake cleaner also later- right before i re-install them.
  13. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    If I'm not feeling poor I use regular parts cleaner. It cleans better than gas and doesn't give you a headache if you breathe it for an hour.
    Otherwise, I use gas. $2 for a gallon of gas is cheaper than $2 for a can of brake cleaner.
    Oh, and I use carburetor cleaner if I need something that won't evaporate quite as quick but will do as good of a job.
    I always rinse with brake cleaner though since it gets rid of residue.
    Don't leave brake cleaner, carburetor cleaner, or gas on seals for long though. It'll ruin them quickly. Brake cleaner and carburetor cleaner will dry out rubber in short order.
  14. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    i finish with alcohol a lot because it tends to get the little dirt. i'll also use lighter fluid, and LIGHT it on bolts, it does the best job, by far.
  15. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    solvent works good, scrub it clean, then rinse it with carb clean.
  16. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    good gawd, whatever you do, DON'T use gas. 1 cup of gasoline vaporized in air to the appropriate degree has about the same explosive power of 15 sticks of dynamite. This is why the fuel-air bombs that the air force has are so devestating. cant stress it enough, dont clean with gas... even in a semi-enclosed area (ie open garage etc).
    j
  17. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ha- dude, don't worry, i know what i'm doing- i know what atomized particle explosions are (what you're referring to) and i know how to prevent them- keep the parts in a COLD area in a CLOSED container, THEN since oil is lighter than gas, pour a thin layer of oil on top of the gasoline to keep it from evaporating.
    i'm not stupid! /forums/images/graemlins/grin.gif but thanks for your concern
  18. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    ok- now there appears to be a small amount of corrosion on my side gears- would a wire brush (on drill press) be ok to get it off?
  19. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    engine degreaser would work well too i bet.
  20. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Why go through all that when you could just use brake cleaner /forums/images/graemlins/confused.gif
