Cleaning rust question
Discussion in 'The Garage' started by k5 krawler 50, Jan 17, 2005.
  1. k5 krawler 50
    k5 krawler 50 1/2 ton status
    Jan 26, 2004
    1,467
    Gardnerville, NV
    I just got a steering box to throw on the blazer, and its pretty rusty. I was going to throw it in the solvent tank, but do you think that will mess up the inside of the box, and will it help get the rust off? What are some other ideas on cleaning the rust off? Thanks for the help.
    Cory
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    I'd use a drill or 4.5" angle grinder and a wire wheel...
  3. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    Thanks for the quick reply,I was thinking about using the wire wheel, i was just looking for some other options as for cleaning it by a liquid, and if solvent was going to mess up the box in any way. Any more ideas would help, thanks.
    cory
  4. tx_sub
    tx_sub 1/2 ton status
    Mar 5, 2004
    548
    Denton, TEXAS
    i'm not familiar with the innards of a steering box, but if there are any rubber seals, the solvent could eat those. my .02 if you happened to overlook that.
  5. k5 krawler 50
    Jan 26, 2004
    1,467
    Gardnerville, NV
    thats a good point really didnt think of that. Has any body ever cleaned their steering box with solvent, or cleaned any thing that carries fluid? thanks
    cory
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Squirting it with some would probably be fine.. But I would'nt submerse it in solvent.. :)
  7. diesel4me
    Jul 24, 2003
    17,534
    920
    Massachussetts
    I wouldnt submerge it either...
    I think it would ruin the seals in the box if you dunk it in a cleaning tank--some of that cleaning stuff is pretty caustic...you could tape up the shafts and smear some grease around them,and have it sandblasted at a machine shop,as long as they are careful not to direct the sand at the critical areas of the pitman arm and steering colum shaft,and you clean it off carefully with brake cleaner and compressed air,you should have no trouble--I've done several of them,and nothing beats a sandblaster for getting all the rust out,even in pitted areas--leaves it ready for a nice paint job--just use care when blasting it....:crazy:
  8. ryoken
    Jun 13, 2003
    29,621
    1,365
    Jersey Shore
    we used to do the same in our blast cabinet... duct tape works well for sealing off areas...
