cleaning the interior and making primer look pimp
Discussion in 'The Garage' started by muddysub, Jan 24, 2003.
  1. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    ok for those of us who still have interiors, and nice ones if i do say so myself! what do yall use for cleanin the interior? the vynil and upholstry. and how do you clean the stock t-case shifter boot? that thing is annoying! ah and how do i make my primer smoother looking? it still looks like it was done with shaker cans (wich it was) you can see lines in it and dark and light spots, how do i fix that?
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Rub the primer with deisel fuel or baby oil, it will give it a good semi-gloss sheen. You could also just rub it down with steel wool to give it an even appearance. </font color>
  3. muddysub
    Jun 23, 2001
    10,451
    489
    are you serious about the baby oil? /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
    steel wool huh? cool /forums/images/graemlins/thumb.gif /forums/images/graemlins/burb.gif
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Real fine steel wool should work pretty well to smooth it out. As for the baby oil, that came from a post on here awhile back. I said that I had heard that rubbing primer with diesel helps protect it a bit and also gives it a bit of a sheen, and someone else replied and said that they had rubbed primered trucks with baby oil and it does the same thing. They said that there was a problem of some sort with the diesel thing... I dunno, neither one should hurt it, try them both out and see what happens! /forums/images/graemlins/thumb.gif </font color>
  5. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I use Armor-all on the shifter boot (just apply with a rag), steering wheel, dashpad, door panels/pouches, steering column, and console. Good looks/protection. The seats...well, I haven't cleaned them with anything...still look good/clean. But, I use Tuff-stuff on the carpet. It's really good.
    As for the primer, I don't have enough of that on my truck to give you tips..........yet. /forums/images/graemlins/smirk.gif
  6. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Cover it with paint. /forums/images/graemlins/smirk.gif Or if your cheap which sounds like the case /forums/images/graemlins/smirk.gif wet sand it with some fine sand paper.
  7. muddysub
    Jun 23, 2001
    10,451
    489
    i like my primer grey, it's cool lookin.
  8. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    On your Vinyl, use Leather Cream for seats. It doesn't dry it out like normal Armor All, mainly this applies in the hot West and South (I.E. Vegas) The boot, any normal cleaner will work. For stains, you could use Resolve, the stuff for house carpet stains. Those cans of stuff for car interiors do NOTHING! I used to work at a car wash, so I fortunately have 3 - 5 gallon jugs of professional carpet cleaner...stuff kicks ass!!
  9. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    [/ QUOTE ] Go to the grocery store and buy a pack of 3M green scrub pads. Rub a couple of them together (to make them finer), drag out your garden hose and start rubbing. I do this between coats of high fill primer whan I paint cars and I always end up with a semi-smooth uniform finish. (No, I do not wet sand with green scrubbie pads. Just between primer coats.)
  10. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    For vinyl and rubber, I've tried and like the Griot's Vinyl &amp; Rubber dressing (which I suspect is simply a repackaged version of "303 Protectant")
    It's got a nice satin finish, not overly shiny like Armor-All and does not contain silicones (like Armor-All) which actually dry out rubber and plastic parts.
    Can't say that I've ever done much "detailing" on my K5, but it seems to hold up well on other vehicles and also seems to repel dust (to a certain extent) too...!!!
    Oh yes, one more thing......never apply this kind of stuff to your steering wheel and pedals!!! Makes for a scary drive!!! /forums/images/graemlins/eek.gif
  11. sdavid
    sdavid 1/2 ton status
    Aug 5, 2002
    244
    Livingston, TX
    I have used Simple Green on everything with good results. Anything rubber, vinyl, tires &amp; wheels, and carpet. Has a strong odor when used in the cab, but will get the greasey foot prints out of the carpet.
