cleaning the MAP sensor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by opfor2, Sep 21, 2004.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    In a past post someone talked about cleaning the MAP sensor and related vac ports. How would one properly clean the sensor and port ?
    Dan...
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I have cleaned MAF sensors but have never cleaned or know any way to clean a MAP sensor. They either work or they dont. I would think you would damage it if you tried to clean it.
    I guess you could clean the electrical connection and check the Vac lines and ports to make sure they aren't plugged or pinched. Sometimes the Vac ports on the manifold will get carboned up.
  3. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    thank you. I guess i'll just clean and check the hose.
