cleaning?
Discussion in 'The Garage' started by 85posjimmy, May 6, 2004.
  1. 85posjimmy
    85posjimmy Registered Member
    Apr 27, 2004
    28
    Cedar City UT
    i am getting my manual and 205 transfer case ready to install, but my trasfer case is really dirty and grimey. what would be a good way to clean it off. i want it all clean when i install it so its nice and clean. thanks Marcus /forums/images/graemlins/thumb.gif
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    pressure wash it and use some degreaser
  3. 85posjimmy
    Apr 27, 2004
    28
    Cedar City UT
    hey thanks for the tip. portland OR huh wow i grew up in vancouver WA pretty neat. thanks marcus /forums/images/graemlins/thumb.gif
  4. motofool
    motofool 1/2 ton status
    Apr 7, 2004
    361
    DFW tx
    go to costco or shucks and buy oil eater spray on pressure wash off..
  5. WhiteWhomper
    WhiteWhomper 1/2 ton status
    Sep 23, 2000
    227
    Highlands Ranch, CO.
    The best stuff I have found to remove grease and gunk, is Castrol Super Clean. You can usually find it at the auto parts stores or Wal-Mart for around 4-7 bucks a gallon and it comes in a purple jug like antifreeze. This stuff works wonders, and it is biodegradable and water soluble. I will usually take a tub a little bigger than my part, and fill up about an inch of cleaner and using a brush and scraper, clean everything and then rise off with the hose. great results. Caution though...this stuff is caustic and WILL remove the first few layers of skin if you use it without gloves. It will also remove paint if you leave pieces in it to soak. A few shops that I know have now replaced thier solvent with this stuff since it is cheaper and works just as well without being flamable.
  6. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    Brake clean works good, and even gasoline. I worked at a transmission shop, and we used brake clean all the time for just about everything. Just spray some on, scrub a little, and rinse
  7. 85posjimmy
    Apr 27, 2004
    28
    Cedar City UT
    i appriciate the quick response. thanks marcus
  8. 85posjimmy
    Apr 27, 2004
    28
    Cedar City UT
    i think all go get so sounds great. thans marcus
  9. 85posjimmy
    Apr 27, 2004
    28
    Cedar City UT
    i'll try some of that also. thanks alot marcus
  10. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    the super clean works great so doed the old reliable brake cleaner and wire brush. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  11. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    Super clean is the sh!t!!! My wife even uses it for everything around the house but windows!! /forums/images/graemlins/waytogo.gif
