Clear-Coat Over Primer?
Discussion in 'The Garage' started by BrianDamage, May 12, 2003.
  1. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    I have noticed small rust spots here & there on my 87 K5. As of now, it still looks pretty good, but it does need a paint job, which is not in my budget right now.
    I have been told that it is not good to primer a vehicle and then not paint it right away, as it can still form rust under the primer..true?
    I have also seen where some of these hot-rod guys are priming their cars & then clear coating over the primer...will this stop the problems associated with just the straight primer?
    I've been laid off the past month, and been working on the K5 nearly the whole time, but am thinking about getting set up to do this on the next lay off (ahhh..the world of consruction). I can lay down a decent layer of primer in my shop, so thinking of doing this myself to thwart the rust and later on get it painted professionally.
    This would also be a good time to buy that cowl-induction hood I've been wanting. /forums/images/graemlins/thumb.gif
    Whaddya think?
  2. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Primer shouldn't rust through unless you put it over bare metal. If you still have a layer of paint underneath the primer you'll be ok. I had my 86 K10 primered for 2 years (over the paint and massive amounts of bondo) and it didn't rust. The best part about primer is if you scratch it you can just touch it up with more primer /forums/images/graemlins/thumb.gif
  3. BrianDamage
    May 14, 2001
    753
    Alabama
    yeah, the parts I'm worried about are where I'm going to have to go down to the bare metal to remove the rust.
  4. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Okay, Primer is poruos so it will allow moisture to penetrate it! As for the clear over the primer I don't know never tried it. If you want good primer try Dupont Europrime, it is the best primer I have ever used. Primer also dies over time due to it not meant to be exposed to the elememts. So chances are to get a good paint job you are probably going to have to re-prime your rig anyway.
    Just my .2
  5. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    if you're removing rust, you'll need bondo right? bondo doesn't rust /forums/images/graemlins/rotfl.gif
