Clear tube for fuel site gauge?
Discussion in 'The Garage' started by BadDog, Mar 21, 2005.
  1. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Anyone know of a good material for a fuel sight gauge? Most clear tubing yellows with fuel over time, but I was wondering if there is anything that will hold up without doing like Brook(IIRC) using a pyrex tube and custom o-ring fittings (that I don't have the skill or equipment to make). So basically, a clear tube that can be clamped on something like a 3/8" nipple and will not yellow within a year or two...
  2. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Ill see what i can get from work tomorrow, do you really care what size it is? and how long a piece do you need?
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    The tank is 10" tall and the fittings are 3/8 NPT I think. So a piece around 9" or so would probably be ideal, and I can get adapters if needed.
    But it's probably not worth the trouble for you to try to get it. I would guess the cost of shipping would be as much as the tube, plus your trouble puts it in the hole. Just knowing what I should look for (and where) would be great.
    Thanks.
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    well its free, and im shure shipping wouldent be that much, ill just look, im hella bored at work anyway:D it will give me somthing to do
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Cool, well, thanks. :D
  6. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    lemme shoot this one by my dad... hes a retired research chemist so I'm sure he knows the scoop.
    j
  7. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Have you looked into what there is on some heavy equipment?
    I know I have seen sight guages on some of the equipment I've been around
    Just a thought
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    check the cycle shops. When I was into quads and dirtbikes we used to have all sorts of see through (clear and colors) tank breather lines, and even fuel lines.
  9. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Most of the commercial sight gauges are pyrex type stuff and have fitted holders, floating balls, and that sort of thing. Not easily adapted to a fuel cell from what I recall, but there might be something I haven't seen or noticed.
    And the normal flexible rubber line like used on motorcycles (at least what I'm familiar with) will yellow eventually with exposure to fuel and sun. Might still be an option and just replace each year or something as it clouds beyond use. I just don’t want to run a gauge.
    Maybe the tube surpip is talking about will be a better solution. :dunno: Kinda interested to see what it's made of…
  10. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Why not just install a premade sight gauge?
    [​IMG][​IMG][​IMG]
    Do a search on www.mcmaster.com for "sight gauges".:D
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Hmm, those are single port, which means they have to vent, so probably wouldn't work on my truggy, considering how often it lays over... Or is there something else that allows it to work that would not leak? Sounds perfect otherwise...
    Edit: Oh, I just found the others...
  12. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    If the top port is plumed into the tank just like the lower port no venting is needed.
  13. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    THIS
    or
    THIS
    Hmmmm... I seem to be on an Aircraft Spruce kick today. Must be because I just got the new catalog (with over 600 pages of goodies).
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Ken, those don't say clear that I could see. :dunno:
    The M/C sight guages like I would want seemed to all be "nylon" or "vinyl" and for hydraulic/lube applications. Didn't say they would support gas.
    So the tank is already buttoned up and just has 2 3/8" NPT nipples top and bottom on the filler side. If I find some sort of tubing that will work, I'll build one. Otherwise, I'll do what I've always done; just fill up before every trip and wing it... Or break down and install an electrical "tube type" sending unit and wire a gauge, but didn't really want to do that.
    Thanks for the ideas guys! :thumb:
  15. jarheadk5
    Mar 6, 2000
    4,389
    PA
    D'OH! Didn't even notice the descriptions didn't say clear...
    The Bing fuel tubing is translucent and has a blue tint to it (and it's made specifically for avgas, which is a little nastier than regular), and the polyurethane tubing is a milky-white translucent. I've worked with both before; the Bing is easier to see fuel in, and easier to work with IMHO.
  16. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    why not use a few inches of standard black fuel hose on each end, and some sort of glass tubing in the middle? resists gas just fine... easy to find, oughta be cheap... and the rubber hose will suck up the vibes etc...
    j
  17. bgreen
    bgreen 1/2 ton status
    Jun 12, 2004
    167
    Alaska
    What you need is TYGON tubing.
    I cant say it wont yellow, but this grade is spec'd for fuel use inside and out. I bought it for my fuel pickup clunk.
  18. bgreen
    Jun 12, 2004
    167
    Alaska
    btw, dont get scared off by that pricing. The stuff I bought was extremely heavy wall so the clunk weight couldnt collapse the tubing. You might consider it though, since the thinner stuff would be more likely to get torn by a branch or rock, etc.
  19. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
  20. az-k5
    Oct 15, 2003
    2,774
    Phoenix AZ
    I say buy the cheapes gas resistant tubing out there and see just how long it will take to yellow. It is only a fuel sight. If you have to take 8 mins to replace $0.80 of tube every 6 months so be it.
    just my .02
