Clear Up A Little Power Steering Line Confusion For Me
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Resurrection_Joe, Apr 14, 2004.
  1. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Can I assume hose are interchangeable from this ?
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Yep, the non-hydro lines are the same...
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    ok, Then what year did they switch to the o-ring type hoses??? My 78 had old style hoses and my 84 had the o-rings?? neither with hydoboost.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I believe they switched to the O-ring style in 81
  5. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Yeah thats the whole problem I've been having, 85 2wd box on a 78 4wd truck, lines are flared type, box uses o ring type
    Honestly, and this may be ignorance talking, but I can;t see why they wouldnt work, the bolt in fine, and are not as some have told be metric unless 3/8ths NPT is metric
  6. dyeager535
    26,979
    They don't work because the 0-ring style seats on a flat surface, and has a flat surface for the o-ring to seal with, and the older type use a flare fitting. There is no seat for the flare fitting on an o-ring box, and there is no flat seating surface in the flared boxes.
    It's not like you are dealing with just 10PSI on those fittings.
  7. Mastiff
    Mastiff 1/2 ton status Premium Member
    Jul 21, 2002
    2,755
    48
    Tucson, AZ
    /forums/images/graemlins/thinking.gif
    I just replaced my steering box and it leaked at the fittings, just a little bit, barely noticeable. The box came with a bag of O-rings, so I pulled the fittings out and saw that one had a smashed up O-ring and the other had no O-ring at all. I put the new ones on and it fixed it up.
    The weird thing is (a) why didn't it leak like crazy with no O-ring? and (b) why was it not leaking at all with the old box and no O-ring, or did the O-ring stick into the old box...
    Oh well.
  8. Resurrection_Joe
    Jan 9, 2002
    17,372
    Gettysburg, SD
    You know, I'm just going to fire the damn thing up when I get the rear shaft back on, of it leaks, I'll try something else. If it works, hey, I have 60 bucks in my pocket still!
    I still have no idea what autozone is thinking
    AND I still want to know if I can use hydraulc hose
    I can't see ANYTHING going wrong with hydraulic hose as if I seal the threads up well, theres no loose connection, it's just there
