clearance issues with....
Discussion in 'The Garage' started by TXsizeK5, Apr 14, 2004.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    a 6" lift and 42x15/15's.
    Do you have clearance issues with the frame/firewall? would moving the axle forward be required? Any pics?
    I already did a search... any pics?
  2. Tweetysuarus
    Tweetysuarus 1/2 ton status
    May 25, 2002
    2,294
    Lynnhood,WA
    I have 38's & 6" lift w/ 2" body lift, I will be removing the 2" for a 1" ORD body lift soon. I have enough room for 44's but the 44's hit the spring pak when turning, 42's just clear.
    [​IMG] [​IMG] [​IMG] [​IMG]
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    if you move your axle forward it will help clear the firewwall, and if your tires are hitting the frame you may have to much back spacing.
