click,click it wont stop
Discussion in 'The Garage' started by screamer*145, May 29, 2004.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    ok I set the valve lash like four times already and it wont stop it sounds like lifter tick. would a colapsed lifter still make that noise even after seting it. i even set it while it was running but to no luck, maby a broken spring?
    if anyone could help it would be great?
    thanks I'll be in the car hold and will check back later!
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/angryfire.gif
  2. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    I believe the best way to set them is with it running. I've seen it where the lock nuts have been worn out and won't maintain adjustment. I would guess a collapsed or leaky lifter may cause that as well.
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    20w-50 oil may help, especially on a higher mileage engine, i only run a particular brand, and alot of people don't like it for weird reasons, but i have definately noticed a difference on noisy lifters, and that is Quaker State 20/50, i used to run Castrol and a few others but this hasd really done me good, i change it out every 2500 or so, keeps it clean, and haven't had any real problems with my lifters.
    Could definately be a bad lifter, a broken spring should be very obvious and i do believe the engine would not run right anyways.
    Are the push rods spinning when you had it running and adjusting them? How many miles are on this motor?
  4. 1-ton
    Apr 17, 2004
    2,889
    165
    Las Vegas, Nevada
    1. Look to see if the lifter, push rod, and rocker arm in question are getting oil. If you do not see oil coming out of the top of the rocker arm, then the lifter is not pumping up.
    2. If your rocker studs are pressed in, and not screwed in, then look to see if the rocker stud in question is pulling out.
    3. If you have a broken valve spring, as you mentioned, then one way to determine this is to try and spin the valve spring in question with your fingers. If the valve spring spins easily, then this can be a sign of a broken spring.
    3. There is also the chance that the lifter is bad, even if it is new.
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    you also may have a bent psh rod, take the rocker off and pull the push rod out, roll it on a very smooth suface, like a pice of glass and you should be able to tell if its bent or not
  6. screamer*145
    Oct 23, 2003
    174
    cottage grove, mn
    your not going to beleave this! new moter, and the first time its happend to me but theres always a first time for every thing? she blew exaust header gasket! /forums/images/graemlins/yikes.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/rotfl.gif
  7. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Those gaskets leak quite easily and should be nothing to get too excited about. Just use a good quality replacement and keep the bolts tight!!!
  8. 4xcrazy
    Oct 31, 2003
    9,472
    5
    use the metal or copper gaskets.
