CLick in frontend and noise with hub engaged
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by FL84K5, Aug 14, 2002.
  1. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    When I'm slowing down at a stop light, at around 10-25 mph I get a click in th front end. Sometimes it is on the drivers side, sometimes the passenger side. I just had the whell bearing tightened and it made the noise before I had them tightened too. Also, I locked by hubs in today in case I needed four wheel drive in the field I was in. With the hubs locked, I get a really bad clunking noise, like somethings binding up front. Never had that happen before with the hubs locked. Any ideas what could be causing these problems? Thanks
  2. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    It's just a guess, but make sure your hubs were assembled properly after the wheel bearing tightening. Mine did that after I did the same thing on both wheels at the same time (didn't have a complete hub as a reference). I found out that I had installed one of the inner 'gear rings' backwards. This may not be your issue, but it might be worth a look.
    Jon
