Clickin Noise! Urgent Help!
Discussion in 'The Garage' started by broncoman6524, Nov 24, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    ok so i drove my truck to a car show today at 60+ for about 1 hour. when i got home i noticed a clickin noise not loud or scary just htere. i go to work, by the time i get htere it is soo bad that just idleing around the parking lot it clicks consistanly every sec or so. I get off work, it still does it, but once i get to about 45ish it goes away. When i got home i sprayed off each wheel. the pass front exploded with steam. I sprayed the hubs/rotors.
    WTF!? is this a sticking brake or a bearing?
    this is my dd and i need to fix it SOON! hahaha the its 10b axles with auto hubs in the front. and come to think of it the pass side hub is blown and doesnt like to unlock. and no its not in 4wd actually my front shaft isnt even in. HELP!
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    The steaming off or your brakes is just because your brakes were a little hot. Probably not related to your problem. Is this problem relative to RPM or speed? We need a little more info.
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    speed, gawd i hope not rpm brand ****in new motor only 300 on it :0 hahah.
    lilke i said, the faster i go the faster the clicking goes. the reason i was concerned with the steam is only the pass side steamed up NOT the drivers. and today my brakes were kinda squeaky in stop and go traffic. hmm
  4. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    300 miles on the new motor? Are you sure you haven't developed an exhaust leak?
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    oooh actually haha thats agood question. hmmm idk ill check that tomorrow. lol i reused my stock manifolds, **** now that i think about it it could be an exhaust leak...its a ticking/clicking noise. hmm ive got a set of hookers in the shop...
  6. Can Can
    15,552
    136
    In my experience, most clicks and ticks are exhaust leak related. Hopefully that's all it is, my friend. Let us know what you find. :thumb:
  7. 1977k5
    May 26, 2003
    9,992
    130
    That was my first guess as well
  8. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    LOL
  9. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    if your rolling slow and hit the brake does it go away?
    Mine does the same, its the pad in the caliper catching on the a warped rotor or something along those lines and the pad probley has oblonged holes from sliding up and down on the rotor.
    tap the brakes real light while your rolling see if it stops if it does, figure out which side and pull the wheel off. I could spin my rotor around fast enough (by the lug studs) to hear it. brakes are good I'm going to let it go for now :dunno::whistle:
  10. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    x2, most likely an exhaust leak
  11. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    not exhaust leak, bc it only does it when moving. it was my rear u-j... im retarted LOL< and i also had a collapsed brake line in the front. that was causing the caliper to stick.
  12. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    good deal, glad you got it figgered out, where is chuluota ?
  13. randy88k5
    randy88k5 1/2 ton status
    Nov 8, 2004
    1,248
    Lynchburg, VA, USA
    Yeah, I had a u-joint go bad that sounded just like that. It was a Napa Precision U-joint, less than 500 miles on it. By the time I tracked down the noise, there were no bearings in the caps, just dust. Greased them too when I installed them. Never using that brand again.
    Glad you found your problems...
  14. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    heh, i used to buy the cheap lifetime warranty joints, 2 at a time, replace the broken one with the new one and go swap it out, after the 2nd or 3rd time breaking a cap, i bought a non greaseable from napa and it worked upuntil i sold the truck
  15. Can Can
    15,552
    136
    Ahhh, the old "marbles on glass" u-joint tick. Yes, I know exactly the sound you're referring to. Thanks for the update, my friend.
  16. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    around the oviedo/ geneva area. south of orlando.
    funny thing...i fixed my collapsed brake line...installed the new extended lines wrong and stomped ont he brakes BAM no more brakey. Hahhaha im an idiot. and come to think of it these were napa brand...
  17. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    Hahaha my last name is Oviedo.
    Chris Oviedo.
