Clicking During Idle...
Discussion in '1992-Present Chevy & GMC models' started by willyswanter, Jan 21, 2003.
  1. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Ok, when my truck is sitting at idle, something clicks on and off on the engine... It will be sitting there and I hear a click and then the idle gets a bit rougher, then a click again about 30 seconds later and it's smooth, then a click about 30 seconds later and it's rough and so on and so on and so on... And no my A/C is not on /forums/images/graemlins/tongue.gif. Anyway, what would this be and whatever it is should it be doing it this often? Oh yeah, 96 vortec 454. All my engine building experience is for pre-efi stuff so I dunno what they have stuck on these things... It sounds like a relay clicking on and off.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Is your defroster turned on when this happens? GM's will kick in the A/C compressor from time to time when in defrost mode. It makes the evaporator coils cold enough to condense moisture in the air and remove it from the air stream. /forums/images/graemlins/cool.gif
  3. willyswanter
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Nope, nothing is turned on. But thats what the sound remindes me of is the compressor turning on and off. I guess I could always just go out and watch the compressor to see if the clutch is engaging... /forums/images/graemlins/rolleyes.gif
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I think my AC compressor does that no matter what the heater/AC setting. /forums/images/graemlins/confused.gif
  5. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Most newer rigs cycle aircond comp to keep seals lubed better.It's irritating,but,they don't lose coolant over winter like old ones, /forums/images/graemlins/crazy.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/thumb.gif
  6. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    mine does it too...its the compressor
  7. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Can you see the comp. pulley engage and disengage?
    It could be your evap purge or egr, both of which use a duty cycle when engaging. Granted neither is supposed to work when idling, but you said the idle is rough. Any codes, or is it the A/C?
  8. bigred350
    bigred350 Registered Member
    Jan 29, 2003
    11
    florence AL
    mine does that to but when its in the off position it doesnt do it
  9. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    When Lift Kit Warehouse lifted my buddies truck they broke a switch on the back of the compressor and his switched off and on, we got a new switch, put it on, now it doesnt click on and off while idling.
  10. bowtiepower00
    bowtiepower00 1/2 ton status
    May 11, 2000
    924
    AZ
    My 93 had A/C and the compressor would cycle even if the A/C was off. My 95 doesn't have A/C so I don't have to worry about it. That empty bracket needs a york... /forums/images/graemlins/cool.gif
