clicking noise
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by kiley, May 8, 2001.
  1. kiley
    kiley Registered Member
    Mar 5, 2001
    87
    Salem, Oregon
    While having fun this weekend I noticed a clicking noise from the front end. It only happened when in motion and especially when turning. My wife said she could feel it in the floor board on the passenger side. I should also mention that it only happened when in 4 wheel drive. I didn't try to see if 4 low or 4 high made a difference but I was in 4 low. Before looking into it I though I should ask the experts. It seems obvious that is in the steering u joints but I'm not sure.
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Try this: Lock the front hubs, but leave the transfer case in 2-Hi. Drive it. If it makes the noise, it's probably the U-joints at the ends of the half shafts. If it doesn't, there's more that needs to be looked at (but they could still be the problem).
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    yep my first thought was axelshaft steering Ujoints.
    Do Dr. Chin's test and that should atleast narrow it down for you.....
    Good Luck
    <A target="_blank" HREF=http://www.burt4x4.coloradok5.com>http://www.burt4x4.coloradok5.com</A>
  4. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    Thanks for replying so fast. I tried that but no clicking. What's next?
    P.S. I got my website sort of up and running.
    http://www.kiley.coloradok5.com
    72 cst
  5. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Let's see. The clicking was not there with the hubs locked but in 2wd. The axle shafts, differential, and front drive shaft spinning but not under load. When in 4wd, the same parts are spinning but it clicks. Sounds like a problem I had in my Ford. Turns out I had a broken tooth on the ring gear. May want to pull the cover and look. JT
  6. chaptr2
    chaptr2 Registered Member
    May 11, 2001
    6
    I just found the same noise in my Blazer, (the guy before me didn't believe in the word GREESE)! I had it for so long and couldn't figure it out. Everytime I put the transfer case into 4hi or 4low it made the clicking noise, it would vibrate and come throught the floor boards along with it amplifing throught the stick. I had someone walking next to me (while I was driving slow in 4 hi or 4 low) thought the noise came from the t-case. Turned out to be the front drive line, u-joints, slip yolk, and that bearing inside the knuckle part (what ever it is called). Drop your front drive shaft first, and then put it into 4 wheel drive, see how that works. Let us know
  7. chaptr2
    May 11, 2001
    6
    Have you found out the problem? I put a new driveshaft in mine and everything works perfect!
  8. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    No. I have not had time to get out again. Plus it's raining in Oregon again and the top is off. I'm waiting for blue skies.
  9. kiley
    Mar 5, 2001
    87
    Salem, Oregon
    Hey guys, I finally got out and listened to the clicking noise. It seems to be coming from the transfer case. It only happens when the steering wheel is turned. I didn't think to check and see if it happens in high and low range. I was in low range at the time.
  10. k5blazerus
    k5blazerus 1/2 ton status
    Apr 22, 2001
    654
    Bend, OR
    try your leaf springs the 4 bolts that atach the spring to the housing
    colin
    IF its not broke dont fix it
  11. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    Check your fliud in your T-case. I would defenatly do ask suggested before and pull your front diff cover and check your gears. If you hear the noise coming from the T-case most likely thats what it is.
    Rasberry 71' K/5 Blazer
    <A target="_blank" HREF=http://www.geocities.com/71blazer>http://www.geocities.com/71blazer</A>
