Clicking When in Park
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by newGenk5, Oct 1, 2001.
  1. newGenk5
    newGenk5 Registered Member
    Sep 14, 2001
    36
    Sacramento, CA
    my next door neighboor just got a 73 blazer......but there is a problem
    when he leaves it in park (e-brake OFF) the car will still roll if it is parked downhill or uphill. there is a clicking noise also....i could only suggest a transmission check but i am REALLY not sure....
    any suggestions, i just feel bad for the guy.......hope to help him out....
    thanks
    keep on rollin
    <a target="_blank" href=http://64.172.156.16/k5>check it out</a>
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Once I accidently threw my blazer in park while I was coasting about 10 mph. It broke the park lever in the transmission. Made the same clicking sound you describe.
    I had a tranny shop fix it pretty easily.
  3. newGenk5
    Sep 14, 2001
    36
    Sacramento, CA
    really......pretty easy huh....that should be a relief for him.......
    thanks a lot.....
    keep on rollin
  4. JST12
    JST12 1/2 ton status
    Aug 29, 2000
    192
    Garland, TX
    Yup, definitely sounds like parking pawl has broken or the tension spring has gone away. You can inspect it and fix or replace it by dropping the transmission pan. The function is pretty straight forward and you can watch the operation if you disconnect the shift linkage and move the lever on the side of the tranny back and forth. You will see the rod pull the pawl in and out of a hole in the trans case.
