Clicking?
Discussion in 'The Garage' started by SUB-ZERO, Oct 28, 2005.
  1. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I have a 85 K5 with 33's.When I turn a corner from a standstill I can here(and kinda feel) clicking in the rear of the truck.I didn't do that before I went wheelin' awhile back(I thrashed it pretty extensively) but now it does.I had put additive in the rear when I bought it cause a friend with a K5 said the factory diff(limited slip is what I believe I have) required it and I didn't know how much it had.I haven't had any problems with it except when I first got it(about a year ago) If I would brake hard while turning sharply(ie. u-turns,etc) it would bind in the rear and I would have to back-up to loosen it.Now it doesn't do that,but I am getting that clicking sound.Could it be the locker(gov-lock or whatever) and should I worry?
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Is it a click or a tick noise? Crap that gets in between the leaf packs can cause that. Also If you have an addaleaf, I have seen them touch the hanger leaf on the end and cause the same thing. If you can reproduce the noise easily, put a c-clamp on one end of the spring(very tight) and see if it stops. You may loose the c-clamp if you go very far.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Very well could be the Gov Loc .
    I would still check what leper mentioned , beter safe than sorry .
    And if it starts feeling funny , like pushing into a turn , get that Gov Loc outta there asap !
  4. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I have the stock springs.So it is likely that I have a Gov-lock?Do I need to replace it with something or can I just remove it?And if its not the springs then it has to be the Gov-lock?I also noticed that I tweaked the transfer case crossmember quite severely.But it doesn't seem to be binding.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    All you can do with a Gov Loc is remove the whole axle and replace it , OR remove the carrier and replace it . Option 1 involves no gear setup .
  6. SUB-ZERO
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I have a 14bolt ff but that would involve a new front axle and new wheels.I was hoping you guys would say"Sounds harmless....let it ride!!" but I guess I'm gonna end up spendin some money before its over.
