clips in
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flblazer, Jul 10, 2001.
  1. flblazer
    flblazer 1/2 ton status
    Nov 24, 2000
    149
    tampa fl
    but i have a little slop in the axle whaT CAN I DO hope its not the gears:"(
    mad crazy k5
  2. dyeager535
    26,980
    A little slop is fine, and normal. (up to about 1/4" or so, since there are a few variables) If you can move it far enough that the c-clip falls back off, or is close to falling off, you have some problems. Did you pull the axle and inspect it, as well as the pinion shaft? (what the end of the axle hits)
    It won't be the gears, unless the thrust washer on that axles side gear has failed, taking the side gear with it. More than likely, that washer may just be worn down a bit, if at all.
    Dorian
    My tech/links page: <A target="_blank" HREF=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</A>
    No anti-theft measures on your truck? No pity when its stolen
  3. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    It is ok to shim the c-clip !
    Get a good book, like the factory shop manual, it will give you the specs. for the play !
    My guess is to keep the play around 1/16 to 1/8.
    Good luck
