Clocking a 241c for clearance pics!!!
Discussion in 'The Garage' started by CCRider, Jan 2, 2003.
  1. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    I am considering clocking my 241c for better clearance , so I can run a flat belly pan , and I can actually lower the rear output for a better angle on the rear shaft , Has anyone done this , and could there be any adverse effects , other than front shaft clearance/binding ( I will address that after) in my 1st pic , it's standard clocking , and the transfer case hangs down 5" from the bottom of the framerails [image]http://coloradok5.com/photos/showphoto.php?photo=3070[/image] in the next pic [image]http://coloradok5.com/photos/showphoto.php?photo=3069&papass=&sort=1[/image] , it is clocked 16 deg. up and only hangs below the rails 2.75 in.!!! measurements to the ground are .....stock 241 crossmember= 23" stock clocking to bot. of transfer case =23 1/4" clocked transfer case bot. of case =25 1/2" !! gain of a couple inches and change!! transfer cases oil pump is still at the lowest point , so I don't think it will be a problem , does anyone have any input ?, know of an adapter to do this with (factory one doesn't have enough meat)? or willing to make one? thanks..........CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Re: Clocking a 241c for clearance
    Here ya go
  3. CCRider
    Jul 8, 2001
    314
    Thanks Scott!!!! how did you do that? ........CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  4. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    You were trying to use the url for the page, not for the picture. Next time right click on the pic then go to properties, copy and paste the address listed there.
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    And where does the shifter end up?
  6. CCRider
    Jul 8, 2001
    314
    You may need to "adjust" the linkage arm back to vertical , but it is closer to the center/pivot point , so it doesn't move up all that much , don't expect it to be a problem at all , I called Advance adapters , and they said they don't have anything that will work , I just need the big part machined out of steel , with the holes indexed properly , and I can weld the mounting tabs that go to the trans mount on myself .............CC
  7. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I need my shifter moved so that is why I am curious. The extra clearance would be cool also.
    Keep us posted /forums/images/graemlins/grin.gif
  8. CCRider
    Jul 8, 2001
    314
    Where ya movin' it to? .............CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  9. tori89k5
    tori89k5 1/2 ton status
    Apr 12, 2001
    946
    Pismo Beach, California
    I like how this is turning out. /forums/images/graemlins/thumb.gif When you get it all done and the bugs worked out a dummy-proof CK5 write up would be great. I look forward to seeing it
    tori89 /forums/images/graemlins/k5.gif
  10. CCRider
    Jul 8, 2001
    314
    I'll take more pics for y'all as I go , could use some help , info, input though guys!!!! Surely I'm not Treadin' on virgin ground here?am I? ...................CC /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  11. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Closer to the drivers seat - I need to build a console for a floor shifter, switches and gauges.
    I have another post abnaking it a solenoid shift /forums/images/graemlins/smile.gif
  12. rockink5
    rockink5 1/2 ton status
    Feb 6, 2002
    693
    Tracy, CA
    I think somewhat. I started thinking about this probably 9 month's ago. I gave a machinist friend an extra 241/208 adapter . We are trying to come up with some sort of clocking ring, Instead of making a complete adapter. Last I had checked he was still working on it. I guess I'll have to call him and see if he's any closer. /forums/images/graemlins/k5.gif
  13. CCRider
    Jul 8, 2001
    314
    I don't see how you could make a clocking ring without losing at least 1/4" of spline engagement , I'll have to check if there is enough , you'd also have to deal with a pilot , so you'd loose the simple 1/4 " plate clocking ring , I may try something though , need to check spline engagement!!! Any more help please!!!...................CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  14. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    I just called him. He's been trying a few different ideas. He did bring up the fact that there is enough material in the adapter that with some work and some rebuilding you could redrill the adapter. We're going to mock up the setup to see where exactly the redrills need to be.
  15. 88K5Jimmy
    88K5Jimmy 1/2 ton status
    Jan 10, 2001
    1,323
    Tulsa OK
    That looks good. How hard would this be to do on a 208?
  16. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    If it can be done to a 241, it should work on a 208. They use the same adapter /forums/images/graemlins/ignore.gif. The only thing that would worry me on a 208 is the oiling, since there is no pump just a slinger. /forums/images/graemlins/eek.gif
  17. CCRider
    Jul 8, 2001
    314
    Is yours different than mine? Mine has ummmmm...........bumps that stick out ad therefore gives the adapter(tc side) enough meat around the bolt holes , If I tried that with mine I would end up with 1/4 of the hole outside the material , and I don't feel comfortable with "slots" If you have an adapter with more meat (round not bumpy) let me know what the part # is (should be cast into it) and I will get a new one and hack on it!!!!..............CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gifoh yeah will work on a 208 as well , but I'd be leery on the oiling system as the pumps were marginal at best already!!...........CC
  18. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    I have the same adapter(s) you do. /forums/images/graemlins/shocked.gif Thats what I mean buy rebuild, you need to add material to where you are going to drill before you drill.
    It can be done! /forums/images/graemlins/thumb.gif
  19. rockink5
    Feb 6, 2002
    693
    Tracy, CA
    Re: Clocking a 241c for clearance *DELETED*
    Post deleted by rockink5
  20. CCRider
    Jul 8, 2001
    314
    Not too sure welding material on a nodular iron piece is the proper way to go about this though , makes the iron REAL brittle around the weld .............CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
