Clocking a T-case?
Discussion in 'The Garage' started by offroadcowboy, May 8, 2004.
  1. offroadcowboy
    offroadcowboy 1/2 ton status
    Jan 29, 2004
    171
    Wittman,Arizona
    I was wondering how exactley you go about clocking your transfer case? would doing this give you a better angle on the f/r drivshafts? or is it mainley for tucking the case up in the framerails? Does anyone make a adapter for this or is DIYS?
    Jeff /forums/images/graemlins/k5.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/k5.gif
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is for a flatter belly pan. It won't help your driveshaft angles any, infact it might hurt the front driveshaft. You may need to get it lengthened.
    A member here makes or has access to clocking rings for NP 208 & 241's. It is a plate that is like 5/8" thick clocks the bolt pattern of the case up.
    Harley
  3. skratch
    skratch 1/2 ton status
    Oct 28, 2003
    1,646
    Gorveport, OH
    The plate is 5/16" thick and DP 90K5 is the one you want to talk to. He has them made somewhere and that's where most of us have been getting them. /forums/images/graemlins/waytogo.gif
