Clocking NP208
Discussion in 'The Garage' started by roadnotca, Apr 24, 2006.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Those that have clocked the NP208 "up", any tips on reworking the selector linkage? As for the case brace, is it as simple as heat and bend the motor end, and grind the slots on the T-case end, if needed? I believe I've already figured-out the cross member, D-shaft and exhaust. This mod is to bring the case up to "flush" with bottom of the frame rails, but I'm not enclosing the T-case with a plate. If I'm that close to hi-center, I'll want spotters.:haha:
  2. smokkey1
    smokkey1 1/2 ton status
    Jan 7, 2004
    2,677
    Los Angeles, CA
    heres some more tips. check out this thread http://www.offroad-tech.com/forum/showthread.php?t=2398&page=1&pp=20 the last couple of pages has good info on to to get rid of the cv front shaft. and were did you get your clocking rig from? if it was from greatlaked offroad I would suggest getting some longer bolts ask jays68yak about it.
    about the other stuff I have know Idea.
  3. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    The gear selector required no additional modification. Just adjust it in, or out, as needed. Throw out the brace.
  4. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    when i had my 208 clocked, i had to lengthen the rod, it was about 1.5" to short. but i had a wierd combo, clocked all the way up with no body lift and the tranny moved 1" to the left, all that caused it to be too short. the rod was pointing way up and to the left. a body lift would have helped here.
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thanks Justin. Yeah its a GLOR. I was in on that thread, I revisited and I don't see longer bolts??
    Why would you want to lose the CV?
  6. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thanks Doug. Pretty cool about the selector. Brace stays; too many broken castings littered all over CK5.
  7. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thanks TJ. Everything else being stock, sounds like the slots will have enough adjustment, I'll bend the front end to point it in the right direction.
  8. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    talk to jays68yak. he did it with his 241.
  9. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    well the bolts that come with the GLO ring are way to short. Jays68yak transfer came off the tranny on an trail in hollister. Btw I bought some longer bolts from mcmastercarr but they only sell them by 25 so if ya need some pm with your address and I'll send them out to you. as for the Cv it's going to bind on you when it flexes out but then again you have a low lift so you should be good. just cleareance the cv and you should be fine.
  10. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Good info here as I am getting ready to do this soon as well. With the removing of the CV. Why would you remove the Cv and go to a single joint? If the CV is binding on droop wouldn't a single joint be worse? Has th longer bolts thing been addressed with GLO? I know about Jay's coming apart, and I heard HD-10's (basketcatch19 on NCBD/SCBD) case came loose there this weekend at the hammers. I know he just did the GLO clocking ring a while back as well. :thinking:
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    without a CV you can run a little longer front driveshaft so that helps with the angles. also the stock CV is not ment to have much angle on it, you will actually have more angle with a single joint than the stock CV.
  12. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    I have know Idea if the bolts have been addressed by GLO. after seeing the pics of jays coming apart cause the bolts were to short that scared me enough to hunt down those bolts.
    GLO bolts to the left and the mcmastercar bolts to the right
  13. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    So you have 1"? I put the question here for the gang, and I'll PM too.
  14. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    It's 1"
  15. smokkey1
    Jan 7, 2004
    2,677
    Los Angeles, CA
    P/N 91253A624 for the longer bolts.
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :haha: :haha: So who's gonna step-up to tell Shawn that his screw is too short.:haha: :haha:
  17. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    I'll PM him :wink1:
    edit
    No PM's so I e-mailed him
  18. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    i had to add about 2 inches to the rod on my truck, also had to smash the floor in, no body lift
  19. greatlakeoffroad
    greatlakeoffroad Registered Member
    Sep 16, 2005
    69
    Indiana
    If anyone out there received a clocking ring from us and the bolts were only an 1" long let me know and we will send out new ones at no charge. We have addressed this issue and taken care of it. There are approx 2 dozen of these out there with the short bolts. Thanks Shawn
    Shawn4x4@greatlakeoffroad.com
  20. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    :eek1: :haha:
