Clocking ring install Question???
Discussion in 'The Garage' started by desertrat67, Mar 21, 2007.
  1. desertrat67
    desertrat67 Hawk Driver
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    How tight are the studs(not the countersunk bolts) supposed to be tightened? I just removed my clocking ring due to it leaking after three attempts to fix it. I then realized how low the 241 actually hangs and would like to get it back installed.
    ryan
  2. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I put mine until they were flussh with the back of the ring. Did you use RTV on both sides of the ring and fill in all the unused stud holes?
  3. desertrat67
    Jul 5, 2001
    3,982
    74
    Dumfries, VA
    Yes I put RTV in the holes, the third time. I think I was overtightening the studs. I torqued them in enough that they left marks on the mounting face of the t-case. Didn't realize this until after I did it though. Could they have been too tight distorting the ring and pulling it away from the mounting surface?
