clocking ring
Discussion in 'The Garage' started by adamforsythe, Mar 11, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Stats:
    Th350
    NP208
    1985 K5 Blazer
    Hello where can I find a good clocking ring for my truck? I want to clock it up so you can't see the t-case.
    Are there any problems that I am going to run ito by doing ths?
    Adam
  2. 91GMCSuburban
    91GMCSuburban 1/2 ton status
    Dec 9, 2002
    318
    San Antonio, TX
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    you need a body lift with a blazer, in my truck i just had to take a BFH to the floor and i think you can do the same to a burb. also the front driveshaft will be at a ugly angle with the factory CV.
    i think im gonna be selling everything from mine, i swapped in a sm465/np208 with the tall adapter and its point less to get the tcase up and still have the crossmember there. i have the short adapter, clocking ring and hardware and the crossmember that i built.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Ok if I clock my T-case as far as I can with out doing any floor mods. Will I need a new front driveshaft?
    Adam
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Hello,
    Shoot me a e-mail with a price.
    adam@yourautoplace.com
    Adam
  6. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    depends on if you keeping your truck stock height or not. you should be fine at stock levels, maybe add a 1" spacer where it bolts to Tcase.
  7. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    Where can I get a spacer?
    Adam
  8. DougK20
    DougK20 1/2 ton status
    Feb 18, 2003
    384
    Boise, ID
    I just clocked my 208 this week. I have apprx 6" of suspension lift and 2.5" body lift. With that much suspension, I would not recommend the highest setting. I just got my new driveshaft and was dissappointed at the CV angle. Even though it's ground for clearance, it's still against the stops at ride height. Will have to upgrade to high-dollar 42deg CV. Any questions, ask away.....
  9. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
