closed dana 60?
Discussion in 'The Garage' started by seanschevy, Jun 9, 2003.
  1. seanschevy
    seanschevy Registered Member
    Dec 18, 2002
    29
    NJ, USA
    I friend of mine just found a closed knuckle dana 60 front axle for me for about $ 250 or less. It has drum brakes to. Is this axle as good as the open knuckle 60. If so except for brakes what do i need to convert it (is it worth it). I am not worried about the gears i need to change them to 513s any how. But i figure if i get it the housing alone probably worth like 200 if its the same as a regular 60 right. Please help. thanks
  2. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    nope not the same, Not nearly as strong, and you cant really convert it, /forums/images/graemlins/frown.gif keep looking /forums/images/graemlins/thumb.gif
  3. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    I thought ALL D60 fronts were open knuckle, 77-91 right? Those would ALL be open knuckle and disc brake axles.
  4. seanschevy
    Dec 18, 2002
    29
    NJ, USA
    i have not seen this axle yet, i am going to look at it prob tommorow. Could it be a dana 70 front i think i remember someone telling me that there were such a thing and they were closed knuckled. If so do any of u guys know how they are (for conversion or strength).
  5. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    It's most likely a Closed Knuckle 70. Later
    -fLeXy K20
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Like others have already said, its probably a D70. I think the only closed-knuckle D60 front is 73-75 Ford crewcab.
  7. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I know closed knuckle dana 60s came on M715 Kaiser FSJs had a 6 lug on 7.25" bolt pattern.
