clunk in D only..but not over D
Discussion in 'The Garage' started by bryguy00b, May 27, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok when im in regular D..(not overdrive) when i stop i get this clunk right befor i come to a full stop..but when its in overdrive...it doesnt do it!..any ideas on that!? thanx..
  2. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I'm no tranny expert, but it sounds like the converter is saying goodbye /forums/images/graemlins/frown.gif My tranny (700R) started doing the same thing this past winter. The clunking got worse over a few weeks. I eyeballed the flexplate first, checked the driveshafts, spring mounts - nothing found. Finally the tranny got scary noisey, I was afraid of being stranded. But would quiet down when the torque converter was in Lock-up. A SWAG (scientific wild-ass guess) would surmise the converter clutch was realigning the stator when it engaged. /forums/images/graemlins/wink.gif
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    im a little lost hear..what exactly is it when its in lock up?
  4. Flexy K20
    Flexy K20 1/2 ton status
    Oct 22, 2002
    398
    Bay Area, CA
    Yeah mine has been doing that for the last 6 months (since I bought the truck) No change, hasn't gotten better or worse. Let me know if anyone figures it out. Later
    -fLeXy K20
  5. Flexy K20
    Oct 22, 2002
    398
    Bay Area, CA
    700R4's troque converters lock up at certain times (spinning a certain number of rpms etc... I dont really remember) They do this so you get better gas mileage etc, because they are not constantly slipping. Later
    -fLeXy K20
  6. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    Someone correct me when I'm wrong, but on 700r4's I think the D position runs a little higher pressure resulting in firmer shifts. This may explain the clunk. I've had two 700r4's that both did the same thing. Lasted for years with no change. Never did it to the extent in Overdrive that they did in drive. I've had both rebuilt lately. One was built stock except for heavy duty steeles and clutches. It also had a shift kit in it. It drove just a little harsh in OD, but really slammed into and out of gear in D. The one that's in my current k5 has the same clutches, steels, etc, but it is an 89 set up (in an 84 blazer). It has more updated pumps, servo's, etc... and you can't tell a whole lot of difference between D and OD. The newer pump is supposed to run more even pressure in all gears at all speeds.
    I've always figured that clunk was your 2 to 1 shift.
  7. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hmm i see...well i guess its nothing i should worry bout then really..besides if it dies in goes the 465 anyway.. /forums/images/graemlins/smirk.gif
  8. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    Could it not just be the tranny going into first gear? Who knows, a little backlash from the rear could cause it as the stress is taken off of it from the downshifting.
  9. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    it does it as its down shifting into 1st i think..
  10. BigOrange90Jimmy
    May 24, 2002
    2,923
    Wilmington, NC
    if you're running 10 bolts, my first guess would be a pinion bearing. second would be a worn out universal. they either work or they don't, or at least that's how it is for me.
  11. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Mine does that too, some say its the slip yoke binding up and you need to grease it. Ive come to be used to it now, I hasnt gotten worse over the past year. /forums/images/graemlins/smirk.gif
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd that. When I had a 700R4 in my big truck, it used to clunk all the time. I always thought it was the slip yoke.
