Clunk in driveline when pulling tranny out of Park....?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Greg72, Nov 28, 2004.
  1. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    It's a minor complaint, but every time I start the truck and pull it into reverse I get a substantial "BANG" which feels like driveline slop being taken up somewhere.
    The rear driveshaft is a nice High-Angle CV-style jobbie that's a few years old (but probably only has 5000 miles on it) there are no vibrations in the driveline at speed. The rear's got a Deeetroit in it, but this problem didn't seem to exist way back when that was swapped in.
    Could this be excessive play in the ring & pinion? Do Detroits get "looser" over time, or is this a classic symptom of a driveline that needs a new u-joint (or three?) /forums/images/graemlins/crazy.gif
    Idears?
  2. elacruze
    elacruze 1/2 ton status
    Dec 23, 2003
    121
    SE Michigan
    Besides the obvious, I've seen vehicles with higher idle speeds (cams, poor tuning, etc.) bang really hard when the motor mounts are shot. Just something to look at.
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I doubt you have the awesomely popular slip yoke going into the transfer case; but if you do, I've read that pulling the driveshaft and greasing up the splines on the slip yoke will help. I've tried it and it works.
    I know I'm smarter than that knowing you wouldn't have something so poser, but maybe there's something in the drivetrain somewhere that just needs a little bit of grease........
    /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    No slip yoke....just the standard 1972 issue NP205.
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Have you greased the slip in the rear driveshaft?
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    get under the truck with wheels chocked and parking brake on. someone else in the rig to go from park to drive and then to reverse. if the d-shaft is moving slop in u-joints or ring and pinion. if the driveshaft isnt moving motor mounts or splines from tranny to t-case.
    im betting on a u-joint or its time to adjust your ring-pinion.
    i also keeping my fingers crossed for you that it isnt tranny to t-case, thats a lot of work for something so small that cna leave you so stranded /forums/images/graemlins/eek.gif
    grant
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Greg, you do have a detroit back there, sometimes mine will do the same if the truck is at an angle. It is normal since the drivetrain becomes loaded when you parked it and the truck settles.
  8. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I'm betting it's a bad u-joint...
    Rene
  9. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    U-joint, probobally the one on your pinion yoke.
  10. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    mine does the same thing but pinion joint is just fine. But mine is in the T-case
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I agree with it being the detroit. My buddies bangs also. There will be more play at the pinion with a detroit, then if there was a standard diff.
    Oh and you dont adjust R&P play.
  12. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Mine started doing the same thing once I put a detroit in it. Probably that, if not I would say Ujoint.
  13. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    My C14FF Detroit has a good 25% rotation from "lock to lock". It can be very noticeable going from forward to reverse, especially if idle is up...
  14. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Would a Detroit get "looser" over time?
    Seems like it's been getting worse over the last 6 months..... the u-joint on the pinion end is a 1410, but I suppose when they go bad it doesn't matter how BIG they are.....
  15. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Not sure about that, I don't think it should change much, but no facts to base that on...
