Clunk when shifting gears
Discussion in 'The Garage' started by MuddNutz, Sep 8, 2004.
  1. MuddNutz
    MuddNutz Registered Member
    Nov 3, 2002
    61
    I am looking at buying a k20 here locally and when we went to test drive it, I noticed it seemed to clunk pretty bad when you shift from park to drive or reverse to drive, pretty much all the gears. It has a rebulit 350 and th400 in the last 12k miles. Any ideas, is this a big deal? Also what is the proper name of the cover that covers the torgue converter and flywheel, it is missing is that a problem?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it could be the ujoints. one of my friends truck does that and he says its the spider gears /forums/images/graemlins/dunno.gif
    i run my truck with outthat dust shield, only problem i have found is mud gets in there easier and kills the starter.
  3. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    I believe you are referring to the inspection plate, as far as it being a big deal I have not run one in ohh about 7 years but I have a SM465 and have found nothing wrong with that now Im sure someone will say different but just telling you I've gotten away with out mine for sometime. I noticed a similiar noise in mine while I was manually shifting the gear while operating the vehicle and it came to be that my body mounts were sooo shot that when I shifted the body would clunk against the frame. Just an idea for you to look into. Good Luck...
  4. MuddNutz
    Nov 3, 2002
    61
    Anyones else got any ideas. The truck kinda jerks at the same time so I don't think its u joints
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Sounds like u joints or excessive backlash to me.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check your u-joints. make sure when you check them you block the tires and have the tranny in neutral so the driveline is not bound up
