clunk???
Discussion in 'The Garage' started by 83PJW, Sep 6, 2002.
  1. 83PJW
    83PJW 1/2 ton status
    Aug 18, 2002
    160
    leavenworth, ks
    i have a clunking sound in my truck when i take off or put it in reverse and i always thought it was my detriot. well read a post (fisher 1468 slip yoke leak) and an individual (cant remember his name) said that it could be the splines banging against one another after breaking hard. not that im second guessing anyone but could this really be my problem and how much do i have to worry about it?
  2. NCblackandredk5
    NCblackandredk5 1/2 ton status
    Nov 12, 2001
    149
    Chapel Hill, NC
    the clunking you are hearing may just be the slak in your tx-case.... most cases haqve some slack in them and will cause a clunking sound.. also check your u-joints... if they aer good, you may have too much play in your axle gears... you say you have a detroit??? did you have to remove the case to install it??? if so did you reuse the same gears??? and also, are you sure they are set up right- ie- do they whine or make noise??? all things to consider but i would have the gear pattern checked if your u-joints and tx-case check out to be ok.... hope this helps!!!
  3. MontanaLifted
    MontanaLifted 1/2 ton status
    Aug 27, 2002
    171
    Heres a simple "free" check...
    From what you described I had the same sound when I first bought my rig. Turned out my rear leaf spring U-bolts were loose. This cause the rear to rotate when I put it into gear. If i put it into drive the rear axle would torque one direction making a clunking noise from the slop. Of coarse it would torque the other direction when I put it into reverse.
    You get the idea. Just try tightening you U-bolt nuts
  4. Frank74
    Frank74 Registered Member
    Aug 28, 2002
    36
    Woodland, CA
    Check your rear axle pinion, my truck does the same, put it in gear, clunk, come to a stop, clunk. It also whines really loudly when I let off my gas pedal on the freeway(4.11s). A Sacramento 4 wheel drive shop told me it was the rear pinion, and some new bearings and such should fix it. Not too big of a deal, shouldn't hurt too bad, but not great.
