clunkin/clicking while driving?
Discussion in 'The Garage' started by TXsizeK5, Feb 10, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    When Im driving i hear clunking and clicking repeatidly coming fromw hat seems to be the rfont axle. What could this be, i was only going about 25-30mph. Any ideas at all, sorry if im being super vague, i have no idea how to be more specific.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Do you have auto hubs?
  3. schmuck
    schmuck 1/2 ton status
    Nov 11, 2002
    523
    nola(new orleans LA)
    easy way to find out is securly lift truck on all fours and start her up and put it in gear and listen but have someone in the truck to shut it down if something happens, you might want to check your front wheel bearings, dose it only do it in 4x4 or are you hearing it in 2wd could be loose ujoint caps and the drive shaft has a little slack
  4. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    2 wd on the street , bearings and brakes recently replaced like a month ago. manual hubs. thanks.
  5. schmuck
    Nov 11, 2002
    523
    check bearings anyway just lift front of truck and grb the wheel at the top and bottom and see if theres any play i replaced mine once and did not realize i had broken the set pin on one of the nuts which allowed it to losen
  6. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Is it clicking/clunking when you press & let off the gas or is it doing it all the time?
    If it's when applying the gas, is your tcase braced? If not, maybe you're hearing the tranny/tcase moving around.
  7. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    no just constant throttle to get it to cruise steadily at about 25mph or so
  8. BigRed89
    BigRed89 1/2 ton status
    Oct 28, 2002
    223
    Los Angeles, CA
    I have the same problem in my '89 Suburban 3/4 ton. The problem occurs below 25mph and doesn't matter if it's in 2WD, 4WD, hubs locked or unlocked. If I apply the brakes, the sound goes away. I have found the problem to be the front caliper bushings that the pins go through to hold the caliper on. I replaced the bushings once and the sound went away. Unfortunately, about a month or two later the sound came back again. I don't know what is causing the bushings to go bad to create this problem, but any other ideas would be appreciated.
  9. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    its not too apparant... i had to turn off my radio and listen for it.
  10. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    Mine was doing that just the other day......I figured Ahh what the heck it can wait till Saturday......diving to work on thursday and some dude in a little escort was honking and highbeaming me......i pulled over and i'll be damed if my entire Hub wasnt on fire.........the locking switch melted ...I havent taken it apart yet but it loook all F*(&ed up ......
