clunking noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudRebel350, May 22, 2000.
  1. MudRebel350
    MudRebel350 1/2 ton status
    May 20, 2000
    324
    N.J.
    When my truck downshifts into 1st gear i feel a clunk coming from the rear of the truck. I'm not sure if its the rear or the driveshaft or neither. When im slowing down and the speedometer hits 15 mph that is always when it happens, sometimes the clunk won't be as bad but I still wanna fix it.
    J.D.
    88 Gmc Jimmy
  2. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    have you checked your u-joints lately....how about your rear pinion seal?
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  3. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Does the truck vibrate when your slowing down? If so that usually is a tip off that your U-Joints are worn down and about to break.
  4. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Also check your motor mounts and the tranny mount...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
  5. MudRebel350
    May 20, 2000
    324
    N.J.
    the truck doesnt vibrate when i slow down. I can't get the plug out of the rear because the previous owner managed to round it out, so i don't want to take the cover off until i get the plug out.
    J.D.
    88 Gmc Jimmy
  6. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    My plug was the same way, but there were a couple of threads sticking out. Used an 6" pipe wrench took some time but it worked.
  7. MudRebel350
    May 20, 2000
    324
    N.J.
    I was thinking of using a pipe wrench, thats a good idea DMK. Great minds think alike
    JD
    88 Gmc Jimmy
  8. slodawg
    slodawg 1/2 ton status
    Apr 30, 2000
    190
    Southern Arkansas
    My plug did the same thing. I took A nut the same diameter as the plug had a friend hold it up to the plug with pliers and tackwelded the inside of the nut to the plug. You dont want to get it to hot or weld it in the case, but if your carefull it will work. Then you can put a wrench on it and screw it out. I used mine like this for awhile. A new plug is fairly easy to get.
    Slodawg
