clunky sound at low speed..?
Discussion in 'The Garage' started by bryguy00b, May 5, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    when ever im criusing really slow say around 5-10 mph i hear this clunky sound and sometimes i can feel it in the steering column or beneath my feet. im thinking maybe u-joint or wheel bearing? im really not sure anyone got any ideas?
  2. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I had a problem like this on my 90 Blazer. The clunk turned out to be caused by loose spring "U" bolts both on the front and rear axle. Check to make sure that they are within spec's
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    that was the first thought that came into my head but i thought nahh...probobly be hard to tighten those there probobly all seized up good.. also i noticed when i stop it will make a slunk liek something is pushing tords the front of the truck. but seems to only do it when im in D but not liek overdrive or anything..
  4. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Do you have automatic locking hubs? If so, try backing up to release them... that's what I have to do. I know it's not the right way to fix things, but it's worked so far. I probably have bad u-joints or something, but I have no job at the moment so I'll have to live with it like that... at least until a wheel falls off /forums/images/graemlins/ignore.gif
  5. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    my CV joint rubs my t-case crossmember. . .but i'm thinking in a few months it'll stop after it gests worn to the point it's too small to touch it anymore /forums/images/graemlins/grin.gif it's nice and shiny new metal where it's rubbing hehe and mine makes a clunky ish noise. . . or could be slightly bad u-joint
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    the noise seems like its getting worse ...it clunks a lot and it does it at higher speeds now..and it seems like somethings loose. something rattles when i go over bumbes..allmost sounds like the axles might be loose..but i dont know if that would cause the clunky sound...its like a scrapping clunky sound...guess first thing i should do is get down there and check the u-bolts with a torg-wrench...and check my u-joints.
  7. khotmer
    khotmer 1/2 ton status
    Oct 23, 2002
    228
    columbus, oh
    sounds like wheel bearings to me....I would fix them NOW....I waited and ended up having to replace everything from the inner bearing out after A FIRE started on the free way...... 1 quick check is to lift the front end and grab the wheel top and bottom and move it back and forth.....if there is any play you found the problem......Mine was so bad that I pulled the tire off without removing the locking hub/outer wheel bearing.....meaning the tire could have come off going down the road...the outer bearing was welded into a little ring that looked like a spacer .........
  8. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hah funny you said that that poped into my head on the way home form school...im about to jack it up to repaint the wheels so ill check that out..thanx man!
  9. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Could be a worn/loose tranny mount...
  10. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    well after getting under there i found that i need a pass side tie-rod end, and there is a tiny bit of play in the wheel on the pass. side..but i think im just going to take out the bearings and re-pack them. also need a new slip yoke for the front driveshaft...but im still not seeing were that noise would come from ...sometimes it will clunk going over a bump....should the t-case mvoe around any? i was able to push it up a little.
