Cluster swap
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DaneW, Jan 29, 2003.
  1. DaneW
    DaneW Registered Member
    Oct 1, 2002
    14
    Washington State
    I'm thinking of doing a cluster swap. I have a the kind with the large speedo and gas. I'm gonna buy one with a larger spedo and tach. I'm a newbie and don't know how to hook up a tach. Will the wires I need already be in place or will I have to pull the wires from another truck. As you can see I don't know what I'm doin. Any help would be greatly appreciated. Thanks much. /forums/images/graemlins/truck.gif
  2. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Alright, I did mine along time ago, and since then have installed an MSD ignition which changes everything. As far as I can remember, you need a 'hot' wire and a ground wire. And you need a wire coming off the distributor cap. On mine(HEI) it is one of the ports in the back of the cap(single prong). Then you will probably need a wire that connects to the lights in your cab so the tach lights will turn on when all the others do. All the wires should be there except the one off the dist. Pick something up at an automotive store for that. As I said, it's been a long time, but I hope this helped a little. /forums/images/graemlins/truck.gif
  3. 77fixer
    77fixer 1/2 ton status
    Nov 22, 2001
    464
    Meridian, ID 83646
    I did mine as part of a wiring swap. I pulled the wiring out of an 80, but for the tach there were 3 wires, ignition hot, ground and tach. The lighting is handled by the circuit board in the cluster the same as on the fuel gauge.
    Brett /forums/images/graemlins/burb.gif /forums/images/graemlins/k5.gif
  4. dremu
    Feb 27, 2000
    15,952
    443
    East of San Francisco
    As others say, it should be easy.
    Now, I lucked out and got a '74 tach cluster for my '74 truck, so it was a direct drop-in. The tach had to be manually wire (ignition power, ground, and the signal from the ... hmm, negative? side of the coil) but that was eeeeeasy. It's just like wiring a car stereo.
    If you have a tach cluster from a considerably different year than you truck, you may be in for some fun -- I know the oil pressure gauges, for instance, went from mechanical in the 70's to electrical by the late 80's. Come to think, the speedo was mechanical on my '74 and is electronic on my '90 Burb.
    Point being, for your '76 you'd want to stick with a fairly close tach cluster -- and good luck in finding one that won't break you /forums/images/graemlins/laugh.gif
    HTH.
    -- A
  5. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    If your changing years, or styles you'll have to pop out the pins and trace the printed circuits and put the pins back in the black plastic holder based on your new cluster.
    The only way you wouldn't have to swap the pins is if you got a same year cluster w/Tach to swap inplace of a non-tach w/gauges.
    If you go from no gauges to gauges, pin swap, no gauges to gauges w/tach, pin swap, gauges to gauges w/tach from different year, pin swap....
    Watch for the number of "tell tale" indicators. Older ones only have 1,or none and the 91's have four, just beware, if you want to retain all the indicators (Brake/4wd/SES, etc) get one with the same number of tell tale indicator slots.
    It's not that bad, just takes a little patience.
    BlazerMan
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    76 older wasmechanical and 77-up electrical i believe, same year as power doors introduction
  7. dremu
    Feb 27, 2000
    15,952
    443
    Dammit, now I gotta go look. /forums/images/graemlins/smile.gif
    My '77 Chalet looks suspiciously like a mechanical speedo -- I sorta figgered the electric speedo wouldn't have happened until the TBI stuff in '87, or at least the computer controller carbs. Evil concept, that.
    -- A
  8. Dale fan
    Dale fan 1/2 ton status
    Dec 5, 2002
    167
    Arkansas
    Pulled this straight off the CK5 specifications page.
    A new electronic speedometer was also introduced for 1990, along with non-asbestos brake linings
    I know my 90 is electronic
