Clutch adjusting problem???...[b]UPDATE / PROBLEM SOLVED[/b]
Discussion in 'The Garage' started by big pappa b, Nov 21, 2003.
  1. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I'm not exactly sure what the deal is. The clutch, pressure plate and flywheel only have about 1000 miles on them and were working fine when removed from the previous truck. When I let the clutch out it barely starts to move about 2" from the top of the pedal. The adjustment rod is basically adjusted all the way out. With the pedal at the top, my adj. rod is barely still in the cup of the shift fork when the pedal is at the top either.
    Any ideas
    SEE UPDATE BELOW
    As I thought, the dumbass at NAPA didn't know what he was talking about. He told me I needed the longer throwout bearing when I really needed the short one /forums/images/graemlins/angryfire.gif
    Took about 3 hours by myself to R&R the tranny/tcase combo. Put a motorcycle lift jack under the crossmember and a floor jack under the trans and pushed it back far enough to get the bearing out. I spent 20 minutes looking for the straps to hold the rear ujoint in. I finally found them right where I left them........screwed into the yoke on the axle so I wouldn't lose them /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Re: Clutch adjusting problem???
    Clutch disc in backwards?
    Rene
  3. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    No. Pulled it out of one truck and put it in mine. Never unbolted clutch..at least I didn't.
    Dan, any chance you took off the clutch assembly when you pulled the motor????
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    I understood that part, however the clutch disc has to go on with one side specifically meant to face the flywheel and the other side facing the pressure plate. The disc is not symmetrical...so it can be installed backwards. There should be some marking saying which side is which.
    Rene
  5. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    The motor I bought still had the clutch, pressure plate and flywheel still attached to it. It was never taken off the motor from the time it came out of dan's truck to the time I put it in mine. He said he never had any problems at all. I'm just trying to figure out what else it could be. I really don't want to pull this thing out if you know what I mean /forums/images/graemlins/ignore.gif
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
    That eliminates that then... /forums/images/graemlins/ignore.gif
    Throwout bearing and clutch fork would be next up. Could the fork have come off the ball and be pivoting on something else? Does it make any noise while idling in nuetral?
    Is it possible the linkage went back together wrong?
    Rene
  7. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I'm thinking about a few other things now.
    I just called Dan and he mentioned something about there being 3 possible clutch forks: manual, hydraulic and something else. I had a 3 speed amnual in there before and I wonder if I could have used that fork instead??
    The other thing I'm thinking about is the throwout bearing. I went to NAPA to get a new one because the old one was still on Dan's 4 speed. The parts guy said it was the long bearing and not the short one. I have the ever famous Borg & Beck clutch.
    Any ideas/hints where to look first???
  8. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yes i would check about throwout bearing, do you know for sure that the old one was same thickness(as tall as) the new one and not different ?
    crap earwax just plugged my ear, cant hear, gotta go,
    goodluck
  9. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I have no clue if it had the long or short bearing. the guy that helped me really knows his stuff sa I took his word for it /forums/images/graemlins/rolleyes.gif Hope that wasn't a mistake
  10. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Hey Dan, any idea if it took the long or short throwout bearing????
  11. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'm having a similar problem with mine. On mine, the clutch won't even come up on it's own. It appears to be that the fork has slipped off the pivot ball, so you might look into that.
  12. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    return spring from arm to frame rail still in good shape ?
  13. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Yeah, it's a new spring as a matter of fact. The springs on the pedals are also in good shape. Going to drop the tranny tomorrow and adjust the fork and see if it's come off the linkage.
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My problem is the total opposite. Mine is a total pain in the ass...won't release all the way every time. Can't wait to ditch this setup....it's sooo frickin stupid.
    Just shorten the length of the rod from the Z bar to the fork and see if it moves the friction point.
  15. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    I think I may know what the problem is, if I have this thought out right. If I have a long throwout bearing then when I release the clutch it seems like the clutch fork needs to release more and the longer bearing may be holding it up from doing that. I really hate to drop that 200Lb thing again dammit!! Not sure if a bearing that is maybe an ince shorter will take care of that but I find out sometime soon..I hope
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    200 lbs? Maybe for tranny alone. Double that for the pair. /forums/images/graemlins/smile.gif
  17. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Yeah, I know. I meant just the tranny. I think I still have scars on my chest and arms from last time /forums/images/graemlins/ignore.gif
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah no kiddin'! Lifting a TH400-NP205 combo yesterday got me to thinking about going back.
    NAH!!!
  19. big pappa b
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: Clutch adjusting problem???...UPDATED
    TTT
    UPDATE AT TOP
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    TTT
    UPDATE AT TOP
    So how do you know which bearing you use? Could this be why my clutch doesn't release correctly unless I adjust nearly all of the free play out of it?
