clutch and brake pedal assembly
Discussion in 'Parts & Trucks Wanted' started by GRAYTEXK5, Apr 10, 2007.
  1. GRAYTEXK5
    GRAYTEXK5 1/2 ton status
    Jul 23, 2002
    281
    Ft. Worth, TX
    anyone have a hydraulic clutch pedal assembly to bolt into a '79 K5? picked up a 32 spline sm465 with the bellhousing and hydraulic parts...now I need the clutch pedal assembly to go with it. thanks.
    John
  2. Jimbo*
    Jimbo* 1/2 ton status
    Mar 8, 2005
    1,420
    roswell, new mexico
  3. bigbanana
    bigbanana Registered Member
    Apr 9, 2007
    25
    Alta Loma CA
    I have all that stuff off a 74. Im not too sure if it will fit. You might need to look around to see if it will work. Name exactly what parts you need and I can give you a price...
    Sean
  4. GRAYTEXK5
    Jul 23, 2002
    281
    Ft. Worth, TX
    you have hydraulic parts off a '74? were they swapped in? a 74 would have had a mechanical clutch. I'm not sure exactly what the difference is...but I know that the clutch pedals are different in some way between mechanical and hydraulic clutches. I need the hydraulic one.
  5. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    I have what you need for $100 plus shipping.
  6. GRAYTEXK5
    Jul 23, 2002
    281
    Ft. Worth, TX
    sent you a pm.
