clutch and flywheel
Discussion in 'The Garage' started by nicotine, Jan 24, 2005.
  1. nicotine
    nicotine 1/2 ton status
    Jan 11, 2004
    116
    wich clutch is the best to put in or will last the longest i am tired of using cheesy clutchs that were out quick. and what flywheel should i use steel or aluminim and should i use the same brand flywheel as the clutch i am going to use?
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    i know that centerforce clutches are highly recommended, but also highly $$$
    i have been told that a good performance clutch that doesnt cost as much is the Luk Pro Gold series, which is what i will go with when it comes time for the 465/205 swap
    as for flywheel, aluminum cost big $, will save you about 18-20 lbs
    so... only recommended if you are trying to save every once you can
  3. sean'schevy
    sean'schevy 1/2 ton status
    Aug 5, 2004
    149
    New Egypt, NJ
    ill second the Luk pro gold. I asked around and thats what most suggested when i needed a new clutch. After ive been wheeling with it for a while now and driving it I am definitly happy with it.
  4. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Back in the day, Centerforce clutches used to be all the rage... from what I understand now you are just buying the name and they aren't worth a $hit. Lots of guys at the drag strip stay FAR away from them because they have trouble w/ them coming apart, and I know from personal experience w/ my dads Cuda' that the Centerforce we stuck in that lasted about 200 miles.
    I stuck a RAM clutch in my rig (like 120 bucks) from Jeg's I think and I have never had any trouble w/ it... and I am not exactly easy on my clutch. It has been slipped, abused, filled w/ water and mud, etc... and still keeps on tickin' like the day I installed it.
  5. nicotine
    Jan 11, 2004
    116
    can you buy just the Luk pro gold clutch disc itself or do have to buy everything?
