Clutch bucking!
Discussion in 'The Garage' started by mtrdrms, Nov 17, 2005.
  1. mtrdrms
    mtrdrms 1/2 ton status
    Mar 14, 2005
    312
    Torrington, CT
    I have an 87 350 Sm465 and lately when I start from a stop the whole truck bucks and kicks and it is very uncomfortable. Is this because my clutch is shot? It only has about 3000 miles on it but it is a napa clutch and I installed it myself so if is quite possible it wasnt installed correctly. What is the best clutch to run for mostly street and some dirt driving?
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Think you could have any leaks? Oil is not good for the clutch/flywheel relationship, and can ruin a fairly new clutch.
  3. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    No leaks that I can see. But you knwo what I didnt do that someone told me I should have, I didnt clean the disc with contact cleaner before I installed it.
    Would that do it?
  4. HEAVY METAL
    HEAVY METAL 1/2 ton status
    Jan 10, 2005
    386
    Maple Ridge B.C. Canada
    i had the same problem last year... turns out my bellhousing bolts backed off... check em and use locktite..
  5. pvfjr
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well it's best to clean them, but I would've thought you would get problems sooner than you did if that was the problem. I have seen a flywheel with a nice handprint-shaped burn in them...
    It's also possible that something just went bad. Check your bolts and look for something obvious. More than likely though, no matter what is causing it, you will have to tear into it. You might as well just pull it apart and then see what's wrong, rather than trying to predict what the problem might be. It sucks to hear, cause I know its a PITA.
  6. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    It sure is!! I was hoping not to have to tear this thing apart again for at least a few year :mad: :doah:
  7. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    did you cut the flywheel?
  8. mtrdrms
    Mar 14, 2005
    312
    Torrington, CT
    it was brand new
